0 members (),
172
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,274 Posts1,058,433 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2004 Posts: 288 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 288 | Okay, my bed rear is sagging 3/4 of an inch. I noticed the shackle that is on there is egg shapped. Can I replace with another shackle or am I screwed? If I figured this out right, if I replace the shackle and compress the leaves tight this should raise the bed up.
Thanks, Chris
Chris 1955FirstSeries
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | Chris, Is the shackle mount worn out or the shackle itself? The shackle can be replaced with one from a supply house or if you need a new mount I have one I took off mine you can have. | | | | | Joined: Jan 2004 Posts: 288 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 288 | It appears to be the shackle, a metal band that wraps around the leaves. I think the problem I may run into might be where the leaves mount, there are no bolts through the bushings, it is welded in place. I mean a rod inserted then welded, instead of bolting it on. You gotta love P.O.'s.
Chris
| | | | | Joined: Mar 2005 Posts: 627 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 627 | Those are not called shackles and unfortunately tightening them up will not solve your problem. It may raise your bed up until you drive it one time and they will be spread apart again. Their purpose is to keep the springs aligned and should not even be tight. They do not hold the leaves together. You need to have your leaves re-arched or replaced. This is common for all of these old trucks, if they were used much at all they are now sagging.
Mike Barnes 1950 GMC 1-ton pickup
| | | | | Joined: Mar 2005 Posts: 627 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 627 | Chris -
The rear springs on my 55.1 were worn so bad they were arched up in the opposite direction. When I installed new springs my truck was raised a full 7 inches! The shackles are what hold the rear of the springs to the frame bracket.
| | | | | Joined: Jan 2004 Posts: 288 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 288 | Thanks all for the input. Sounds like re-arcing is in order. I can get them re-arced for a reasonable price, just go to figure out how I'm gonna get them off.
Thanks, Chris
| | | | | Joined: Mar 2005 Posts: 627 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 627 | You are in for some real fun. Don't know what you'll pay for re-arching but it is a hell of a lot of work that justifies new springs while you are there. You can replace them for a hair over $100 each if you can avoid shipping costs.
Make sure you block the truck up very securely in front of the springs before getting underneath!
| | | | | Joined: May 2005 Posts: 314 Shop Shark | | Shop Shark Joined: May 2005 Posts: 314 | If the problem is just a missing bushing, cut the shackle off and buy or make a new one... replace bushing... Good to go! | | |
