4 members (Jon G, Gray_Ghost, Bill Hanlon, MRMEROTH11), 85 guests, and 0 robots.
Topics128,068
Posts1,055,881
Members48,428
#18702 06/04/2002 2:22 PM
I drove the 39 for the first time in nine weeks
and begun thinking about power steering...1.Sooner or later they are gonna bypass me.That's gonna mean no truck drivin for awhile with Armstrong steering.
And 2. I don't think my girl can park it.
So any ideas
NO I'm not giving up the girl!!!
She can drive the SS elCam
#18703 06/04/2002 4:37 PM
I hear your leg hurts more than your chest afterwards.
54 3100 with 235
62 flatbed dump C60 with 261
#18704 06/04/2002 7:25 PM
What about those booster kits that use a servo valve mounted between the pittman arm and the drag link and a separate piston? Then you don't have to hack up the truck. Something like this:
Steering assist kit tech article
If I was doing it I might consider doing it that way.
Paint & Body Shop moderator
#18705 06/04/2002 7:29 PM
I heard there was Toyota stuff that fit
Wantta race me with your non=hacket-up truck?
Look at my truck on the gallery....It's So Cal Stock!
Seriously I have 39 steering not 40 up it's not much fun!
#18706 06/04/2002 8:15 PM
Here is a link to the Toyota PS conversion. I have thought about adapting this type of set up to my 51 Chevy??
Toyota PS Conversion
Kelly
1951 Chevy 3100
1967 RS/SS Camaro
#18707 06/04/2002 9:12 PM
Thanks but I said I wanted to USE Toyota stuff not put it in a Toyota!
It's strange how much money some will spend instead a buyin a Jeep
#18708 06/04/2002 9:29 PM
Awe it is good to see the ol Proffit back. we missed ya dude, and you need to keep that armstrong steering now you got the youngin in your life you need to keep fit heheehehehehehe,
Alan
Live every day to the fullest for tommorrow never comes!!!
#18709 06/04/2002 9:33 PM
Jim , have you thought about putting a 46 pickup s/box in ? I believe they are lower geared and they ARE much lighter to turn when parking . smile
#18710 06/04/2002 9:36 PM
Jim,maybe forget the power steering. 2 years ago I installed a 41-47 recirculating ball Saginaw steering box in my 37 pick up.Its a bolt in job more or less.I had exhaust clearance interference with one of the 2 exhaust pipes.A hammer blow took care of that. Your 39 has the same high friction antique box as my 37.It now steers with the same effort as an AD truck,even with 215 section radials,its good enough.I have to thank Barry weeks who told me the boxes would swap easily.
#18711 06/04/2002 10:11 PM
Thank you ....There's no need to send money....I have enough
I want the P.O.S. to have P.S.
#18712 06/04/2002 10:23 PM
Yeah , yeah ,,,,,, we know that Jim ,,,,, Tony and I were just trying to keep the truck GM grin
So whats the difficulty with using a GM power box ? you have a good chassis rail to bolt it to.
I just checked 4onthefloor suggestion ,,,, I had one of those ram assist setup on my LandCruiser , it worked good off road , in that there was no steering kick back , and was easy to drive on the road ( 11" Cooper tyres ) ,, but parking was still hard ,,,,, the rig didn't have enough power assist .
A power box is the story ,,,, may have to box the chassis some .
#18713 06/05/2002 1:08 AM
JH,
The problem as I see it is that all the PS boxes are big and cross steer. They get in the way unless they are front mount with a lot of U joints and stuff. For a drag link type setup, some of the roadster guys that want cowl steering are going with a Dodge 70's type box that can be mounted on it's side. It's aluminum too. LOL.
I've seen a power steering rack that was rear mounted, but was mounted to the axle with a splined joint for suspension purposes. The alignment and the ackerman worked out, but it looked too much like it came from your area (Mickey Mouse)LOL. Just a couple of ideas for you to ponder.
Regards
Dennis
#18714 06/05/2002 1:42 AM
Way back when someone told me to use a Toyo 4 runner box and marry the drag link.....I remember BOX THE FRAME but can't remember who
It's tough getting old 'specially when I've not got my young lady to remind me stuff!
You guys only got me for two weeks then I'm back to Europa
Did you see where I told Oily to [censored] on a fence to keep the vermen away!!I hope somebodies keepin track a you clowns when I'm gone!
#18715 06/05/2002 3:01 AM
Oly Offline
Proffit, I would even [censored] on a few Coyotes, if I thought it would do any good, but it would probably only make them smell like a man.
If you can't drive your 39 anymore just send it my way, and when you can't... just send.... I'm never to old to drive old trucks or .......
You might try a suicide knob on the steering wheel.
Oly in Oregon
Rest in Peace
1945 GMC COE Victory Truck
1953 Willys CJ3B
1955 Chevy 1st series 3/4-ton
1958 WIFE Last series
Never say "Whoa" in a mud hole
#18716 06/05/2002 4:28 AM
Jim, I think the article you may be thinking of is located at www.classicperform.com/power2.htm
I scabbed onto a Saginaw power steering box out of a 60's Chevy pickup to put in my 51 should I decide to do this someday. Without reading the entire article again, I kind of remember the author being a little uncertain about one of the mounting bolts. I seems that only two of the bolts hook to the frame and an "ear" has to be welded to the frame for the third bolt to go through. I don't think it would be that big of a deal to make a little better mounting system. I also remember Phat saying something about when you turn hard right the inside of the tire will rub on the steering box, but with a little planning, this could be handled.
BTW, I recently aquired a 248 GMC engine out of a 51 GMC 350 truck. I want to use this engine in my 51 Chevy pickup after making the necessary adjustments for the GMC's longer length. Are there any peculuarities I need to be aware of regarding the 248.
Good to have you back, come again when you can stay longer grin
Remember 9-11-01--God Bless the USA
JUSTICE, not REVENGE, will prevail
1951 Chevy 1/2-ton Pickup truck
#18717 06/05/2002 4:36 AM
As you can see you must make a mount for the front
and move the rad forward
248 likes a lotta cam and not as mush lift as the
270/302
Make a water connection from the back of the head to the pump to let the water syphon up.
Melling makes a high pressure oil pump and get the big pan off a bus
Oily....when I'm too old you'll be rolling a chair
around.....and [censored] WORKS!
#18718 06/05/2002 5:52 AM
Maybe Dusty's got the idea
RC....there ain't nothing there that looks like my truck but closer than Toy/eep
Maybe I was dreaming!!
Then Oily woke me up
And I've routed rather stupid/large pit bulls by [censored]... so it works....maybe just not for you
Jus kiddin...but it does work!
#18719 06/07/2002 4:27 AM
JH,
The Toyota 4 runner steering box is from a '79 to '84 model. I could e-mail you an article from a 1994 magazine that describes the installation on a Fxxd pickup, but according to the fellow who sent Jenny and I the article, the procedure is the same for a Chevy or GMC. You need to be able to open MS Word to read it.
Also, we are interested in your disc brake conversion in the tech articles section. But what is a Toyota "hardbody"? I kind of remember the name from their advertising...
#18720 06/08/2002 12:54 AM
52, that's a NISSAN (a.k.a. Datsun) Hardbody. The little rigs they made from about 1987/88 up until the Frontier came out (1996?)
Wannabe smile
"Don't expect anything and you'll never be disappointed"
