3 members (klhansen, Nick in Manitou, UtahYork), 82 guests, and 4 robots.
Topics128,080
Posts1,055,953
Members48,430
#186984 08/06/2005 2:07 AM
Hi,
After doing a search I see why no one replied to my post ""56-3200 Dual Master/Front Disk Conversion??" There is a boat load of good information and answers to this topic, but..... After purusing almost all the info I found, it seems that the real answers that I was looking for are lacking. The manual dual master is pretty much a piece o'cake but the offerings for disc conversions for a straight axle ala 1956 etc. are limited and not quite what I would like to do. Let's see,
#1: I can convert to front disk and still use 6-lug wheels but can't use the original rims without modifying the rims or calipers (why bother) while spending pretty big bucks. hhmm..
#2: I can convert to Camaro style calipers and rotors that were made for the weight of a car (not a loaded pickup truck) with a non truck lug pattern while increasing the width between the front wheels giving it the awkward look that putting a classic truck body onto a late model frame gives. Still kinda spendy. hhmm....
After a lot of research and brain twisting I may have come up with another option that I would like opinions and thoughts on.
#3: Have the stock spindles machined, sleeved and shortened to use standard 1/2 ton '73 and up 5-lug Chevy pickup rotors and have a caliper bracket made for the '73 and up calipers. The rotors and calipers are mui plentiful, comparitively inexpensive, have a truck lug pattern and are made for the weight of a loaded pickup truck. cool I have actually found someone who regularly does similar sorts of fabrication and machine work who quoted me a price of around $400 for the machine work and the brackets ready to bolt on, even as a "one off" job. I realize that this sounds a bit pricey at first, but look at what you end up with in convenience, price for replacement parts, and the right equipment for the job. If several or more of us straight axle owners wanted to do a similar thing this would no longer be a "one of" job and we could probably get the price a bit lower.
smile
So, what do ya all think? Is this a good plan or is all the fun I had in the late '60's early '70's coming back to haunt me?
All replies are eagerly welcomed,
Gene&Jr.
horseballz
'56 Chevy 3200
'69 Ford F250
'68 Mustang Coupe/5.0 Roller/T5/Factory A/C
'03 Miata (Wifes Ride)
looks like you've done your research
And make sure those caliper brackets are made from some high-strength steel. I don't want to be on the road with anyone whose calipers are moving around.
1954 GMC De Luxe COE
The CPP 5-lug conversion kit or the Chevy Duty one is priced the same as your machine shop estimate and you won't be scrounging around wrecking yards for used parts to put on your truck.
Thanks for the replies,
I have no desire to scrounge boneyards for brake parts, instead I was talking about new rotors and "loaded" calipers from a parts house. I guess maybe you missed my point about not wanting to use light duty car brakes with the small lug pattern and I certainly don't want no jap scrap on my 56 "Made In The USA" Chevy truck, yet I would still like to go with the large 5-lug pattern wheels. Also the machinist I was talking about is actually Steve from Buffalo Enterprises in Washington state, really good guy and eager to help. http://www.inliners.org/buffalo/ Please keep the replies comin' and let me know if you see any real downside to using real chevy truck brake parts that are readily available on a Chevy truck. I figure by the time I buy all the correct Chevy truck brake parts NEW and have the fab and machining done I wil still be in the same ballpark as the price for a complete kit that uses Camaro parts.
Thanks again,
Gene & Jr
horseballz
'56 Chevy 3200
'69 Ford F250
you can get 6 lug conversions and 6 hole spacers - 423$ at American Classic
