3 members (FishinToms53, Gdads51, Gray_Ghost), 80 guests, and 0 robots.
Topics128,052
Posts1,055,740
#18689 06/04/2004 11:57 PM
I have a 1950 3/4 Ton and just rebuilt the head. In the process, I ordered another oil line that supplies the rocker shaft. Well, when I unscrewed the nipple from the block, it loosened OK but I cannot get it out of the block. Is it fastened inside the block? Do I need to remove the oil pan to get to it?
Thanks for any help.
Michael
If you are talking about a 1950 Chev motor, the rocker supply that you see coming from the area of the side cover, is part of an assembly that comes through the block, through the water jacket, from the driver's side. Is this a Chev engine that we are talking about ?
1951 1 Ton Completed
Thanks! You are a life saver. I just couldn't figure out how it was attached. I would have never guessed it went through the block.
