2 members (49 panel, Nick in Manitou), 22 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#186787 08/03/2005 6:15 PM
Just got my new gas tank sending unit for my 54 from the TruckShop..Been trying to get the old screws out..I have clutch head drivers, and vise grips..I believe the PO (Fool) put some kind of sealer on the threads..the farther I get them to come out, the tighter they get..Taking a break, after shooting them with PB..I guess a torch and grinder would be out of the question..Just kidding..Wish me luck, looks like an all day project..Steve
#186788 08/03/2005 6:31 PM
Alright, I think I have a solution..Got out my Dremmel and am gonna cut a slot in the screws (not loose enough for fumes yet) and get a big flat blade and go for it..Still gonna need some luck though..Steve
#186789 08/03/2005 8:47 PM
dont understand why they are so tight, they are not very long either,,, have you ever tried to un-screw something and be going the wrong direction..
Redryder pix
My Hotrod
#186790 08/03/2005 9:39 PM
Leftly loosey, righty tightly..Come on Fred..By the way, what kind of wood did you use for your side rails..Got a line on some Walnut,Thanks,Steve
#186791 08/03/2005 11:14 PM
IN abd OUT A little at a time.Just like the ?????
dan-pa
#186792 08/03/2005 11:58 PM
Uh Huh..
#186793 08/04/2005 1:56 AM
Insomniac
Insomniac
The part of the screw that projects into the tank is probably rusty.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
#186794 08/04/2005 3:16 AM
I filled my tank full of water and heated the screws red hot with my torch. Worked for me, but it still took a while, After wards I found the sending unit was garbage any ways. Then I found a few rust holes in my tank. Total wipe out!!!! But I got the broken sending unit out and welded up the holes.
#186795 08/04/2005 4:06 PM
be a lot faster if you would buy a new tank for that new sender.... grin just kidding,, have you got the old sender out yet.FRed
Redryder pix
My Hotrod
#186796 08/04/2005 4:09 PM
Nope, just shooting some PB on the screws, and giving it time to work..While that's happening, I'm stripping about 4 coats of paint and some black sticking stuff from my running boards to get them back to bare metal and prime..One thing I've learned when getting older is patience..Used to never have any, now I've got a little..Take care Fred, Steve
#186797 08/04/2005 4:12 PM
Boy, that was a 3 min response,, but then that is about how long it takes me grin
Redryder pix
My Hotrod
#186798 08/04/2005 4:15 PM
Well, I'm inside waiting for the stripper to work..Glad I'm not paying her by the hour.
#186799 08/04/2005 4:17 PM
I
I Offline
Be sure and take some Pics... grin
IRWIPI 2005 Peoples Choice
Inky,
"It's not that I haven't done IT... It's that I haven't done IT yet."
'48 1-1/2 ton Dump
'57 Chevy Panel
'59 Chevy 2 ton Dump
#186800 08/04/2005 6:08 PM
boy, you 2 or on top of it.......Fred
Redryder pix
My Hotrod
#186801 08/04/2005 6:15 PM
One running board done..Paid for a new outfit and told her that I had one more to get done..Tomorrow is a new day, gotta work on my sending unit, Steve
#186802 08/05/2005 8:19 PM
Glad you got it working, now you wont run out of gas on the way to Riverside Mo.............if you stay after anything long enough you can un-screw it...Fred
Redryder pix
My Hotrod
#186803 08/05/2005 8:54 PM
Thanks bro..didn't even throw much, and my neighbors said they didn't hear a thing..This getting old ain't all bad..Got my stripper working again today..These running boards are gonna get pretty expensive by the time I'm done..Oh well, It's a beautiful day..Dream on,Steve
