3 members (Shade Baby, Steveoreno, moparguy), 136 guests, and 6 robots.
Topics128,266
Posts1,058,386
Members48,485
#185857 07/24/2005 12:35 AM
Junior Member
Junior Member
I did a search, and didn't find exactly what I was looking for, here's my Question:
In this '53 3600 I'm working on(Fighting With), We are going to have to go to a modern engine/tranny, but we'd like to keep the original clutch pedal, how can I do this? Same question with the brakes, we want to go to power brakes, is there a way to do this and keep the factory brake pedal? I really don't want to keep the master cylinder under the cab, but I guess I will if I have to.
#185858 07/24/2005 4:59 AM
You can keep both with some fabrication. For the clutch, mine worked with a mid 70's bellhousing and clutch set-up with no mods. The brakes can be mounted on the fire wall. Just line it up with the pedal rod so they match and fabricate a bracket to push a clevis and pin equipped master cylinder (can't remember from what donor to get one from). There's conversion kits for almost anything that you may want to do to this era truck also,
Good luck,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#185859 07/24/2005 5:06 AM
Junior Member
Junior Member
Thankyou for your reply. I really wanted to be able to keep the stock pedals. Another Idea I had on the brakes, would be leaving the master cylinder where it's at, only adding a small diameter power booster, and running a remote fluid resivoir up under the hood.
#185860 07/24/2005 5:41 AM
wink
You can do that. Check with MP Brakes. Do a Google search and you will find MP Brakes and others.
Joe
#185861 07/24/2005 8:11 PM
With a little ingeneuity, and an understanding of basic geometry, it shouldn't be hard to adapt the original pedal linkage to your needs. Things like the booster, and the clutch master cylinder will have to be mounted under the cab, however. Be sure to provide for an access hole for filling/checking, or fabricate remote reserviors.
