4 members (Wayne67vert, Phak1, TUTS 59, Hush), 113 guests, and 0 robots.
Topics128,095
Posts1,056,069
Members48,433
#185842 07/23/2005 3:09 AM
Y
Junior Member
Junior Member
Y Offline
How can I find the original paint color or code to my truck? It has had a few colors and I'm not sure which is correct. I think the primer was black, but not sure. Thanks
#185843 07/23/2005 3:11 AM
Y
Junior Member
Junior Member
Y Offline
#185844 07/23/2005 5:19 AM
The only Chevy trucks that i'm aware of that had factory paint codes stamped on them were the Canadian models.
In every old truck i've seen, the original body color was visable on the firewall or in the door jams (unless it was fully repainted)
#185845 07/23/2005 1:51 PM
Y
Junior Member
Junior Member
Y Offline
Thanks,That would make it red. Can you still buy the original colors, or do you just get it close?
#185846 07/23/2005 3:09 PM
There was a thread not too long ago that had a link to a page with the different colors used.. as I recall there were a few different flavors of red.
Use the search function on the board (use the one just below the "post reply & post new topic buttons) and search for "color codes" and that will yeild alot of good info and numbers for outfits that can supply you with factory paint colors.
#185847 07/23/2005 4:34 PM
Jim Carter "Classic Truck Parts" sells what they believe are the original and correct true color of paint.
http://www.oldchevytrucks.com
Paint on pages 133-138 for exterior.
Word hard, play harder, enjoy life!
#185848 07/23/2005 8:09 PM
Y
Junior Member
Junior Member
Y Offline
THANKS
