2 members (ndkid275, Phak1),
58
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 11 Junior Member | | Junior Member Joined: Jul 2005 Posts: 11 | How can I find the original paint color or code to my truck? It has had a few colors and I'm not sure which is correct. I think the primer was black, but not sure. Thanks | | | | | Joined: Jul 2005 Posts: 11 Junior Member | | Junior Member Joined: Jul 2005 Posts: 11 | | | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | The only Chevy trucks that i'm aware of that had factory paint codes stamped on them were the Canadian models.
In every old truck i've seen, the original body color was visable on the firewall or in the door jams (unless it was fully repainted)
| | | | | Joined: Jul 2005 Posts: 11 Junior Member | | Junior Member Joined: Jul 2005 Posts: 11 | Thanks,That would make it red. Can you still buy the original colors, or do you just get it close? | | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | There was a thread not too long ago that had a link to a page with the different colors used.. as I recall there were a few different flavors of red.
Use the search function on the board (use the one just below the "post reply & post new topic buttons) and search for "color codes" and that will yeild alot of good info and numbers for outfits that can supply you with factory paint colors.
| | | | | Joined: Jul 2005 Posts: 135 Member | | Member Joined: Jul 2005 Posts: 135 | Jim Carter "Classic Truck Parts" sells what they believe are the original and correct true color of paint. http://www.oldchevytrucks.com Paint on pages 133-138 for exterior.
Word hard, play harder, enjoy life!
