5 members (Jon G, Hush, 1955 1 Series, Shade Baby, Gray_Ghost), 227 guests, and 1 robot.
Topics128,102
Posts1,056,185
Members48,436
#18584 05/08/2003 10:19 PM
Junior Member
Junior Member
I am trying to remove the rubber portion of the front motor mount on a '54 235 engine that is in my '50 1/2 ton AD. I have jacked up the front of the engine and pushed up the four (4) motor mount bolts with a punch, but the bolts do not seem to go high enough so as to allow me to extract the rubber piece. I would greatly appreciate any advice on this matter.
#18585 05/08/2003 11:34 PM
as I recall, two of the bolts allow you to remove the top cover plate, wherein you can then remove the other two.
1951 1 Ton Completed
