3 members (sron48, 1955 1 Series, Southerntruck), 37 guests, and 10 robots.
Topics128,010
Posts1,055,308
Members48,419
#185765 07/20/2005 8:11 PM
Installed the Pertronics Ignitor on my '57 283 with a '74 distributor, in my '55.1. Only problem was the holes in the little shim washers were a 1/2 hair too small. I opened them with a drill bit. Easy installation for a novice. Just need to remember to reconnect the vac advance tube (and the vac tube to the tranny that I did not realize I pulled off). All is well in the Great North, it is running smoother than ever.
The BIG question is why does my speedo work now? Before it wandered all over the place, now it is rock steady???
Buddy
"Keep the shiny side up....."
'50 GMC Suburban
'55 1st Chevy Pickup
http://community.webshots.com/user/buddyinak
prolly cuz it's warm weather and all the crud in the speedo cable has softened up - try pulling the insert out and cleaning it well, and inside the sleeve too
Could be you unknowingly un-bent a kink or tight bend in the cable housing while you were working on the ignition. That happened to me while installing a stereo once.Happy mistake!
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
2 Offline
Voo doo electronics.
Yeah I installed a Pertronix ignition on my 56 GMC w/288 V8 a while back and I was pleased beyond words at the difference it made.(Discovered my coil was bad in the process, but I still think the module made a difference.)
