3 members (cmayna, TUTS 59, 1 invisible),
146
Mod | | | Forums66 Topics128,070 Posts1,055,896 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 1 Junior Member | | Junior Member Joined: Jul 2005 Posts: 1 | I have the chance to get a cab off of an early chev truck (1947 to 1953). The question i have is the cab the same on a 2 ton truck has it is on a pickup of the same year? appreciate any information you may have.
Thanks | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | On '47-'55 1st series Chevrolets, the cab, is the same, on all models 1/2 ton, thru 2 ton. On '47 -'55 GMC's the same cab was used on, 1/2 ton thru 5 ton. Anything larger than a 650 series 5 ton GMC Conventional, used the GMC Heavy Duty "Big Cab". | | | | | Joined: Feb 2000 Posts: 132 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2000 Posts: 132 | spanky, 54-55 1st cabs are different. look at the windshield.
i miss obscene phone calls...
| | | | | Joined: Aug 2001 Posts: 44 New Guy | | New Guy Joined: Aug 2001 Posts: 44 | The fenders on the bigger trucks were larger. The front grill is smaller on the 1/2 ton PU. Check the cab mounts, the earlier years were different 47/48?. If you have the later year chassis w/ 4 point mounts, then all you have to do is drill some extra holes. If you can get (or put) the outside gas tank, then you have extra room behind the seat for those extra pack rat- type items.
41 Chev 2dr coupe 51 3100 w/a 261 11 Camaro RS ragtop
| | | | | Joined: Mar 2005 Posts: 627 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 627 | tomslik -
kpthorne's question included the key phrase you overlooked "same on a 2 ton truck has it is on a pickup of the same year".
Spanky knows what he is talking about.
Mike Barnes 1950 GMC 1-ton pickup
| | | | | Joined: Jul 2005 Posts: 1 Junior Member | | Junior Member Joined: Jul 2005 Posts: 1 | Cabs Are the same but fenders are different | | |
