7 members (crenwelge, JW51, Lostbuthaulinass, Hugh63c10, Gray_Ghost, 1955 1 Series, greenie-reddy),
161
Mod | | | Forums66 Topics128,108 Posts1,056,237 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#18531 01/07/2003 1:29 PM | Joined: Dec 2002 Posts: 55 Member | | Member Joined: Dec 2002 Posts: 55 | Tapered wheel bearings seem to go for about $175 per truck set...does anyone know an actual manufacturer's name and the bearing #'s used? I have the option of buying these things at a discount bearing place, if I knew which numbers I need. | | |
#18532 01/07/2003 9:50 PM | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | I have checked all of the bearing dimensions for the ball type front wheel bearings and researched a bearing cat. and did not find any direct replacement roller bearings. This was done for a 1954 1/2 ton. I suspect that spacers are used to make up the difference.
Anyone who has used the conversion bearings will be able to verify the bearing numbers as well as the use of a spacer. | | |
#18533 01/08/2003 4:10 AM | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | I found 2 repro places that list roller bearings for my task force trucks, but haven't found anybody so far that knows the manufacturers #'s for them, and have tried using the ball bearing dimensions at a number of places w/ no luck. the rollers will be more expensive no matter, but should be at least 20- 30% less from a bearing supplier. got one last place working on it . . .
Bill | | |
#18534 01/08/2003 1:44 PM | Joined: Dec 2002 Posts: 55 Member | | Member Joined: Dec 2002 Posts: 55 | Thanks for your help, guys - the company I work for buys ALOT of bearings, and the bearing supplier we use said he would put some effort into trying to locate #'s if we had dimensions; I'll try to measure mine and see what he can do Thanks again! | | |
#18535 01/08/2003 6:36 PM | Joined: Jun 2002 Posts: 26 Junior Member | | Junior Member Joined: Jun 2002 Posts: 26 | We just did a disk brake conversion from Chevy Duty that came with tapered bearings (great kit). If I had their catalog with me, I'd check - you might see what they could give you. I'm pretty sure they sell the tapered bearings by themselves as well. - rick | | |
#18536 01/03/2006 6:54 PM | Joined: Mar 2002 Posts: 384 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 384 | ever find it? Might be timken B52 and B01 but not sure. Thanks - Scott
55 1st Chev.
#18537 01/03/2006 10:03 PM | Joined: Feb 2005 Posts: 531 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 531 | Recently installed roller bearings on my 56 3100... Chevy Duty Part # 73-031 ('47-59 inner), $45.95ea; 73-061 (47-57 outer) $29.95ea; 73-111 (47-59 grease seal) 6.95ea
Mfg numbers off the parts: MBS (Japan): Inner bearing race: 909052R; outer race: 909001R
They're working like a charm (knocking on wood...) | | |
#18538 01/03/2006 11:26 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Part of the agony of this bearing fiasco is the $$$ issue. As Larry Bear indicates, the outer wheel bearing and race for ONE side is $29.95. I don't have the cup (race) price, but a brand new Timken bearing (cone) is $6.99 at your FLAPS! My guess on the cup would be $3.50.
I think you are paying for their R&D and packaging..this is probably OK, but WOW, what a markup.
Stuart | | |
#18539 01/05/2006 4:36 PM | Joined: Nov 2004 Posts: 117 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2004 Posts: 117 | Here is the information on the tapered roller bearings you need.
Inner 909052R Outer 909067R Seal 6064 (National)
cgresham1212 If you don't drive it, why have it? 55 1st Series 3100 5 window
#18540 01/06/2006 1:07 AM | Joined: Mar 2001 Posts: 629 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 629 | I have all the bearings I need but wil be guessing when i put everything together. Anybody out there have some tip, instruction, photos or hints?
Tim Sheridan 1947 First Series Chevy 1/2-Ton"Liberty Series" - "Art Deco" - Whatever you'd like to call it. In the Gallery | | |
#18541 01/06/2006 2:56 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Tim,
Are you installing tapered roller bearings in your '47...is this what the tips would pertain to?
Stuart | | |
#18542 01/06/2006 3:41 AM | Joined: Mar 2001 Posts: 629 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 629 | Originally posted by atomarc: Tim,
Stuart Yep
#18543 01/06/2006 4:42 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Tim,
I don't know if you need a blow by blow on the bearing installation..is it improper to tag something like this onto this thread?
Your pictures indicate you have tons of work ahead of you on the front axle and brakes, is the bearing retrofit down the line a touch.
Stuart | | |
#18544 01/16/2006 6:42 PM | Joined: Mar 2002 Posts: 384 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 384 | Thanks to all for your replies. I was just trying to get that high price down. I apologize for my slow reply...I was off for a front end alignment on my twice broken nose. Functional not cosmetic. Thanks - Scott
55 1st Chev.
