1 members (delky),
65
Mod | | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2005 Posts: 95 Member | | Member Joined: Feb 2005 Posts: 95 | ok i went to home depot and lowes looking for quick roof or peel and seel... nothin
but i found some stuff that was a sticky foam backing, with aluminum foil ish stuff.. it was about 1/8 inch think.. i think made by frost king, for drainpipe insulation.. will this work the same??? | | | | | Joined: Jun 2003 Posts: 331 Member | | Member Joined: Jun 2003 Posts: 331 | If you phone a roofing supply store they should have peel and seal.I used this as sound deadner with a double layer bubble wrap with foil on both sides. They use it for isulating of walls, pipe and many other uses. I am very happy with the results | | | | | Joined: Feb 2005 Posts: 399 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2005 Posts: 399 | I found mine at a RV center..They use it on the tops of trailers/RVs | | | | | Joined: Oct 2003 Posts: 363 Member | | Member Joined: Oct 2003 Posts: 363 | That drain pipe stuff is fantastic, I haven't been able to find it, can you please post the name brand and where you found it (store and location in the store).
A friend of mine covered the entire inside of his plymouth sedan with it and it was as quiet as a new cadillac.
I like the pipe insulation a little better than the bitumen roofing stuff cause it doesn't have petroleum distillates in it.
Thanks, Chris | | | | | Joined: Apr 2004 Posts: 543 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 543 | One thing you have to watch with sound deadeners is if it absorbs/retains moisture. Condensation is inevitable wherever you have a metal surface, and if your deadener holds moisture in anyway, you've given rust a giant foothold.
Something to consider!
Pessimist - Sees glass as half-empty. Optimist - Sees glass as half-full. Gov't- Sees glass and takes it from you because you have a glass. Political Correctness: A philosophical belief system bereft of common sense and logic, that supports and rewards ignorance and stupidity.
| | | | | Joined: Oct 2003 Posts: 363 Member | | Member Joined: Oct 2003 Posts: 363 | Which is exactly why the pipe insulation works so good, it is for wrapping and protecting cast iron pipes. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I get my peel & seal type roof repair at Home depo. It,s hard to find but I finally found it on the end of the aisle They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
