2 members (Ponchogl, Hush), 67 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
#185209 07/10/2005 7:24 AM
ok i went to home depot and lowes looking for quick roof or peel and seel... nothin
but i found some stuff that was a sticky foam backing, with aluminum foil ish stuff.. it was about 1/8 inch think.. i think made by frost king, for drainpipe insulation.. will this work the same???
#185210 07/10/2005 7:55 AM
If you phone a roofing supply store they should have peel and seal.I used this as sound deadner with a double layer bubble wrap with foil on both sides. They use it for isulating of walls, pipe and many other uses. I am very happy with the results
#185211 07/10/2005 12:59 PM
I found mine at a RV center..They use it on the tops of trailers/RVs
#185212 07/10/2005 1:35 PM
That drain pipe stuff is fantastic, I haven't been able to find it, can you please post the name brand and where you found it (store and location in the store).
A friend of mine covered the entire inside of his plymouth sedan with it and it was as quiet as a new cadillac.
I like the pipe insulation a little better than the bitumen roofing stuff cause it doesn't have petroleum distillates in it.
Chris
#185213 07/10/2005 3:54 PM
One thing you have to watch with sound deadeners is if it absorbs/retains moisture. Condensation is inevitable wherever you have a metal surface, and if your deadener holds moisture in anyway, you've given rust a giant foothold.
Something to consider!
Pessimist - Sees glass as half-empty. Optimist - Sees glass as half-full. Gov't- Sees glass and takes it from you because you have a glass.
Political Correctness: A philosophical belief system bereft of common sense and logic, that supports and rewards ignorance and stupidity.
#185214 07/10/2005 4:10 PM
Which is exactly why the pipe insulation works so good, it is for wrapping and protecting cast iron pipes.
#185215 07/10/2005 5:26 PM
Riding in the Passing Lane
I get my peel & seal type roof repair at Home depo. It,s hard to find but I finally found it on the end of the aisle
1972 Chevy c10 Cheyenne Super
