2 members (homer52, Tronman),
113
Mod | | | Forums66 Topics128,077 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#18519 02/10/2003 8:13 PM | Joined: Feb 2003 Posts: 28 Member | | Member Joined: Feb 2003 Posts: 28 | Hello,
Is an SM420 Transmission, an SM420 Transmission? Did they ever vary?
I just purchased on line, because of the great price, and am not sure of the year of it.
However, I have a 51 GMC Truck, long bed.
Will any SM420 work?
Need to know!
Thanks!!!!
Dallas
Broccoli is for chopping, classic trucks are for restoring!
-51 102 22 C GMC
#18520 02/10/2003 8:17 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | They have two kinds of outputs, torque tube and open driveshaft, with or without a parking brake.
#18521 02/10/2003 8:38 PM | Joined: Feb 2003 Posts: 28 Member | | Member Joined: Feb 2003 Posts: 28 | Ok, Well, dont outbid me (grrrrr) but here is what I am aiming for: web page I think my 3 on the tree setup now is a torque tube. Ideas on how this will work? Dallas
-51 102 22 C GMC
#18522 02/10/2003 10:34 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Ok, that is the open driveline model, if you don't want to loose the torque tube then you will want the closed driveline version, which is less desirable by most anyway and someone might even swap you for it. The bellhousing is separate from the transmission so you will not need it. If you put a want ad in the swap meet I'm sure someone can hook you up with a torque tube version.
#18523 02/11/2003 12:42 AM | Joined: Jan 2001 Posts: 45 Member | | Member Joined: Jan 2001 Posts: 45 | Dallas Check the shipping might cost a bunch to get to Colorado. I learned the hard way Even if you can get one for free the shipping will make it very expensive, them things are heavy. Just my opinion Mike | | |
#18524 02/11/2003 12:49 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Read the fine print. No shipping available.
Fred 52 3600 69 C-10
#18525 02/11/2003 1:33 AM | Joined: Feb 2003 Posts: 28 Member | | Member Joined: Feb 2003 Posts: 28 | I appreciate all the feedback. In regards to the fine print, I read it, and contacted the seller, in which he'd be willing to crate it for 25 extra dollars, and ship.
I work for FedEx, so uh.. .well that works out.
However, I'd like the closed drive line version, so I am not going to bid again on that transmission.
I am going to post a want ad for the transmission.
Other than the transmission itself, and the floor cover w/hole, are there any other things I need?
Thanks again,
Dallas
-51 102 22 C GMC
