3 members (Wheelie, Ole49GMC, GMCJammer51), 98 guests, and 3 robots.
Topics128,030
Posts1,055,430
Members48,422
#18517 05/12/2004 2:31 PM
49 3600 has the stock lever action shocks. The manuel instructions for filling them with fluid say remove front cover and replace with one that has a fill plug(!?). I have wire brushed all 4 and cleaned with solvent. The front cover has NO fill plug. The only openeing I can find is toward the top back of the shock and it has a slotted head. This appears to be the relief valve comparing to the manuel. I'd like to keep the shocks, but can't figure out how to fill them.
#18518 05/12/2004 3:23 PM
I've seen those covers with a fill plug, it's just a small pipe plug near the top. Just pull off the covers and drill and tap for small pipe thread. Would be a quick and easy solution.
1946 1/2-Ton Chevy
