4 members (WICruiser, Bill Hanlon, Hanks custodian, 66flea), 235 guests, and 3 robots.
Topics128,078
Posts1,056,049
Members48,433
#185121 07/08/2005 9:51 PM
Anyone here lowered a C20? Everyone's always doing C10's. With the recent air suspension technologies, it seems one could lower a C20 and still be able to haul a load.
I'd like to do this on a budget so I was thinking about doing new 3" drop C10 springs on the front and a bolt in airbag kit for the rear. This way I'll be lower but still can haul plenty.
Anyone have thoughts?
-David
Tradin' up dimes for nickels...
My \'65 Chevy C-20
#185122 07/08/2005 10:26 PM
The basic differences are the spring rates & the heavy 8 lug hubs & rear axle. I don't see why your plan wouldn't work, but I have read on the net 3" drop front springs makes for a rough ride. Why not bag it all around? Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#185123 07/09/2005 2:03 AM
A front bag kit adds $500+ to the cost of lowering. I thought the new dropped coil springs were designed to lessen the rough ride caused by springs that have been cut to get lower. Guess I'll have to ask around on that one.
-David
My \'65 Chevy C-20
#185124 07/10/2005 7:13 PM
Anonymous
Unregistered
Anonymous
Unregistered
I was thinking about this the last little while, and I thought that it was a great idea. I also heard that drop coils are designed to lessen the rough ride (thought I read it in a magazine). So in the back, you would swap out the coils for 'bags, and then what? Would you have an onboard compressor?(expensive) or would you just have the air valves coming out somewhere and you can fill them wherever? How much weight can two bags in the rear hold? You could do the same with a half ton aswell right? Thats a good idea.
#185125 07/11/2005 5:42 PM
Yeah, I was thinking a compressor. Air Ride offers one for $350. Thought I'd check around and research a bit though. Seems like I read somewhere about people who've used AC compressors for an air source. Plenty of those in the boneyard!
As far as I know the bags will carry quite a load. I talked to one guy with a bagged Toyota truck who said he hauls more than the factory intended on a regular basis.
-David
My \'65 Chevy C-20
#185126 07/11/2005 6:27 PM
The big square York/Tecumseh a/c compressors are used often to run bags. Brian
