1 members (Hotrod Lincoln),
72
0
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2004 Posts: 543 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 543 | Anyone know of a 5- or 6-lug axle that'll bolt up in place of a '41-'46 1/2-ton rear axle??? I found a 235 close by, with tranny, from a '59, so I know the enclosed driveline will go away. I've heard a S-10 rear is the same width. Anyone know for sure what will be the same, in terms of width???
Pessimist - Sees glass as half-empty. Optimist - Sees glass as half-full. Gov't- Sees glass and takes it from you because you have a glass. Political Correctness: A philosophical belief system bereft of common sense and logic, that supports and rewards ignorance and stupidity.
| | | | | Joined: Jun 2005 Posts: 221 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 221 | I think the S-10 will be about right but measure to be sure before you install it | | | | | Joined: Jan 2004 Posts: 255 Member | | Member Joined: Jan 2004 Posts: 255 | Hi Patrick, There is a link somewhere that shows all the widths and gearing of many replacement axles that will work on your truck. I have a hard copy of it at the house, but its listed somewhere here on the board. A lot of people use the 70's Blazer with 6 lugs. The S-10's have 5 lug wheels and are about the right width as well. There are also some Camero rears that will work. Hopefully somebody will come up with a link. PS. I will be in OK City the night of the 16th on our way to Branson. I will give you a call. My wife was wanting to go see the brickyard and I wanted to see the Bass Pro shop if there's time. Ralph | | | | | Joined: Feb 2005 Posts: 399 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2005 Posts: 399 | | | | | | Joined: Apr 2004 Posts: 543 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 543 | Ralph, sounds good, looking forward to seeing you guys again!
