5 members (Gdads51, klhansen, Otto Skorzeny, Steelonsteel, 1 invisible), 76 guests, and 1 robot.
Topics128,051
Posts1,055,710
#185046 07/07/2005 10:00 PM
Anyone know of a 5- or 6-lug axle that'll bolt up in place of a '41-'46 1/2-ton rear axle??? I found a 235 close by, with tranny, from a '59, so I know the enclosed driveline will go away. I've heard a S-10 rear is the same width. Anyone know for sure what will be the same, in terms of width???
Pessimist - Sees glass as half-empty. Optimist - Sees glass as half-full. Gov't- Sees glass and takes it from you because you have a glass.
Political Correctness: A philosophical belief system bereft of common sense and logic, that supports and rewards ignorance and stupidity.
V
V Offline
I think the S-10 will be about right but measure to be sure before you install it
Hi Patrick, There is a link somewhere that shows all the widths and gearing of many replacement axles that will work on your truck. I have a hard copy of it at the house, but its listed somewhere here on the board. A lot of people use the 70's Blazer with 6 lugs. The S-10's have 5 lug wheels and are about the right width as well. There are also some Camero rears that will work. Hopefully somebody will come up with a link. PS. I will be in OK City the night of the 16th on our way to Branson. I will give you a call. My wife was wanting to go see the brickyard and I wanted to see the Bass Pro shop if there's time.
Ralph
rtlopez@shipleysystems.com
48 Chevy 3600 w/235
48 Chevy 3100 w/235:
You cant see the smoke on a dirt road.
Ralph, sounds good, looking forward to seeing you guys again!
