1 members (1 invisible), 105 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
#184991 07/07/2005 9:50 AM
Junior Member
Junior Member
I'm not sure which catagory this question should go to. I have a O.E. (I think) steering stabilizer on my '52 1/2 ton panel. I need the rubber bushings for it. Anyone know where I can buy them? Thanks
#184992 07/07/2005 1:27 PM
Never heard of an OE steering stabilizer but Chevy Duty sells an aftermarket.
If you are talking about the anti-sway bar, Jim Carter oldchevytrucks.com has the bushings.
Mike Barnes
1950 GMC 1-ton pickup
#184993 07/07/2005 2:33 PM
fat fenders,
If you referring to the anti-sway bars, they were OE on at least the 1/2 ton Panel & Suburbans and might have been OE on the Canopy Express.
There are two styles of bars/ bushings but there should not be confusion if you have an original 1952 bar (that is the later style and is shown in the 47-55 Factory Assembly Manual, if you have one).
Tim
#184994 07/08/2005 12:32 AM
Junior Member
Junior Member
Thanks Tim. Yeah, that's what I'm referring to. My assy. manual calls it a stabilizer. Although the manual I have ('48-'51) does not show a photo.
I'll try the link you've posted.
#184995 07/08/2005 2:08 AM
fat fenders : i got mine at jim carter. they look very near identical. I have a 53 chevy panel. I also have a 47 GMC panel (parts truck) the sway bar on it is slightly different ,looks original, but not 100% sure it is.
I don't suffer from insanity, I enjoy every minute of it!
#184996 07/08/2005 11:04 AM
Junior Member
Junior Member
I think I'm going to try the bushings from Jim Carter. It pretty much looks like those are the ones I need.
