| | | Forums66 Topics128,035 Posts1,055,443 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 18 Junior Member | | Junior Member Joined: Mar 2005 Posts: 18 | I'm not sure which catagory this question should go to. I have a O.E. (I think) steering stabilizer on my '52 1/2 ton panel. I need the rubber bushings for it. Anyone know where I can buy them? Thanks | | | | | Joined: Mar 2005 Posts: 627 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 627 | Never heard of an OE steering stabilizer but Chevy Duty sells an aftermarket.
If you are talking about the anti-sway bar, Jim Carter oldchevytrucks.com has the bushings.
Mike Barnes 1950 GMC 1-ton pickup
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | fat fenders, If you referring to the anti-sway bars, they were OE on at least the 1/2 ton Panel & Suburbans and might have been OE on the Canopy Express. There are two styles of bars/ bushings but there should not be confusion if you have an original 1952 bar (that is the later style and is shown in the 47-55 Factory Assembly Manual, if you have one). Tim | | | | | Joined: Mar 2005 Posts: 18 Junior Member | | Junior Member Joined: Mar 2005 Posts: 18 | Thanks Tim. Yeah, that's what I'm referring to. My assy. manual calls it a stabilizer. Although the manual I have ('48-'51) does not show a photo. I'll try the link you've posted. | | | | | Joined: Mar 2005 Posts: 267 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 267 | fat fenders : i got mine at jim carter. they look very near identical. I have a 53 chevy panel. I also have a 47 GMC panel (parts truck) the sway bar on it is slightly different ,looks original, but not 100% sure it is.
I don't suffer from insanity, I enjoy every minute of it!
| | | | | Joined: Mar 2005 Posts: 18 Junior Member | | Junior Member Joined: Mar 2005 Posts: 18 | I think I'm going to try the bushings from Jim Carter. It pretty much looks like those are the ones I need. | | |
