2 members (J Lucas, pauld),
123
Mod | | | Forums66 Topics128,183 Posts1,057,263 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#18457 07/06/2004 7:12 PM | Joined: Jun 2001 Posts: 169 'Bolter | | 'Bolter Joined: Jun 2001 Posts: 169 | 1951 1/2T Torque Tube Axle. I need to replace the rubber splash seals that go on each side of the spring perch on the rear axle.
Before I go to the trouble of making them, does anyone know a supplier that is selling them? Tried Chevy Duty, LMC, Jim Carter with no luck.
Paul Wisner | | |
#18458 07/08/2004 2:14 PM | Joined: Jan 2002 Posts: 2,845 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,845 | Paul, Here ya go......
Heavy Chevy Truck Parts of AZ
Rear Axle Swivel pads # 2080
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
#18459 09/09/2004 4:08 PM | Joined: Jun 2001 Posts: 169 'Bolter | | 'Bolter Joined: Jun 2001 Posts: 169 | The saga ends. After waiting 2 MONTHS for Heavy Chevy to deliver the axle mount pads I cancelled the order. I figured I could plant and grow a rubber tree in the same time it was going to take for these jokers to deliver. I went down to a local (KC,MO) rubber supply house to get some flat material to make my own. While talking to the counter guy he says "We can make those for you if you want". 2 hours later I had some EXACT copies for a little more than pocket change money. I'm not sure why so few of the truck vendors list this item? Maybe because nobody replaces them? The book says they are for minimizing noise and that sounds good to me. Paul [img] http://www.whcinc.com/images/P9030001.JPG[/img] | | |
#18460 09/09/2004 10:17 PM | Joined: Nov 2003 Posts: 117 Member | | Member Joined: Nov 2003 Posts: 117 | Paul, where does it say they are for are for minimizing noise? I've searched and cannot find the reference. I have the 48 to 51 Chevrolet Truck Shop Manual.
Winona 1949 3100 5 Window Deluxe Cab
