5 members (Stovebolt48, 78buckshot, baldeagle, Napco Mark, TooMany2count), 69 guests, and 5 robots.
Topics128,021
Posts1,055,346
Members48,420
#184351 06/26/2005 8:52 PM
Got to sort the door glass in my 63 GMC fleetside; driver's door's got no felt left, glass just dropped off the runner and gone down into the door, fortunately not broken. The spot welds on the channel had snapped but should be able to stick them back with "plastic metal". The passenger side window's not been used for so long, the glass is stuck shut! So while I'm doing one I might as well fix the other, too much rain over here in the UK to leave the window open permanently! grin
Question; in the Chevy Duty parts book, two types are specified, one with metal frame and one without. What is the difference please and which is better to use as replacement?
63 GMC Fleetside; overbuilt, over-thirsty and over here!
#184352 06/26/2005 11:22 PM
Tab Offline
I bought the Chevy Duty window rubber kit which included both doors the front windshield and the rear window. I just recently replaced the door rubber and window molding.
Which part are you talking about? The kit that I got had metal runners for the window guides. It worked ok. The only problem that I had was that the felt on the pieces which go on the bottom of the window opening. The felt was to thick and the metal window runner at the base of the window hit it keeping the window from rolling up all the way.
delete my account and pictures
#184353 06/27/2005 12:18 AM
On page 3 of the PDF catalogue, the "Door Felt Kit"; it says that for 1960-63 trucks you should specify "with or without metal frames around edge of door glass". My problem is that i'm not too sure which one I need. First truck I've owned, and over here there's not often another in the same county, let alone town, to compare to!
#184354 06/27/2005 5:01 AM
What they're wanting to know is if your window glass has chromed metal trim around the edges, or if it is just a bare plain piece of glass. If you roll down your window and just the glass edge is there, you need the kit WITHOUT chrome trim.
Regards,
Wannabe smile
"Don't expect anything and you'll never be disappointed"
#184355 06/30/2005 7:13 PM
Great! Thanks very much for the info. Now over to the Chevy duty shop to increase my credit card debt!
You might guess I'm not stopping at the ONE item! grin
#184356 07/01/2005 5:41 AM
Tab Offline
Have fun. The installation is a PAIN IN THE BUTT. wink
#184357 07/09/2005 11:54 PM
Pain in the ARM you mean; good job I've got slim wrists and "musician's fingers", Houdini would have fun doing this job! grin
Got it fixed now, off to my first show tomorrow, just a local vintage thing with cars, tractors and a few steam engines (stationary and road-going) weather's looking fine!
No prize expected tho unless they have a "Best See-Thru Bed" category; must get that yellow pine ordered! smile
