| | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 6 Junior Member | | Junior Member Joined: Jun 2005 Posts: 6 | Can anyone tell me the difference between 3/4 & 1/2 ton trucks? (other than the obvious rearend, 8 bolt wheels, etc) Is the body the Same? | | | | | Joined: Jan 2002 Posts: 622 Member | | Member Joined: Jan 2002 Posts: 622 | Floating rear axles.
The body is the same.
What year?
delete my account and pictures
| | | | | Joined: Jun 2005 Posts: 6 Junior Member | | Junior Member Joined: Jun 2005 Posts: 6 | Sorry Forgot the year 1948 | | | | | Joined: Jun 2000 Posts: 454 Shop Shark | | Shop Shark Joined: Jun 2000 Posts: 454 | All cab and front end sheet metal is the same. Bed will be longer on the 3/4 ton. Best bet is to pick up a copy of the Factory Assembly Manual and get yourself a Restoration Pack.
Jeff Nelson
"Beer is proof that God loves us and wants us to be happy." - Benjamin Franklin "Always do right. This will gratify some people and astonish the rest." - Mark Twain
| | | | | Joined: May 2005 Posts: 26 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 26 | on the 3/4 ton (long bed) the spare fits w/o a "dent" in the rear fender
'50 Chevy 3600
| | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | Except that side-mount spares weren't available from the factory until '53...
3/4-ton trucks also came standard with 4-speed SM420 transmissions. The drivelines are open rather than the torque-tube setup which was used through '54 on the 1/2-ton models. The brakes are larger all around. | | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | The cab is identical. The frame is heavier gauge on the 3/4. Wheelbase for 1/2 116", 3/4 125". Bed length 1/2 6.5', 3/4 7.5'. Tires 1/2 has 4 ply, 3/4 6 ply. Gearing 1/2 4.11, 3/4 4.57. Springs 1/2 8 leaf, 3/4 2 stage 7 or 8 leaf.
Brakes. I don't have specifics on the 48, but the 1/2 had smaller brakes than the 3/4.
Tranny. 1/2 had either 3 speed column or 4 speed floor with one-piece enclosed driveshaft. 3/4 had only 4 speed floor with two-piece driveshaft, front half enclosed, rear half open.
Differential - 1/2 had a semi-floating differential, where the axles are loaded with weight of the truck. 3/4 had full-floating, axles carry no weight, only driveline (power) load.
1/2 ton 6 lug wheels, 3/4 8 lugs.
If you are trying to decide on which to get, I would recommend the 1/2 ton, mainly from the standpoint of availability of wheels, tires and suspension upgrades. Front suspension packages are available for the 1/2, not for the 3/4. Rear end swaps are easier to make, with many possiblities. Wheels and tires are also easy to obtain.
Fred 52 3600 69 C-10
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | hey!! smarten up!! 3/4T's never had the short bed, but 1/2T's came in short or long bed Bill | | | | | Joined: Jun 2000 Posts: 454 Shop Shark | | Shop Shark Joined: Jun 2000 Posts: 454 | Originally posted by red58: 1/2T's came in short [b]or long bed[/b] In the AD series they didn't. There was no such thing as a "short" or "long" bed available for the 1/2 tons. All of the AD 1/2 tons had the same bed length.
Jeff Nelson
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | really!! :confused: they stopped makin long 1/2's for 7 years and then started again? wow Bill | | | | | Joined: Jul 2002 Posts: 188 Member | | Member Joined: Jul 2002 Posts: 188 | Only GMC's had the 1/2t long bed with thier more powerful and fully presurized inline 6's. I think the 1/2 t beds are too short and the 3/4 ton bed is proportioned better. My .02 | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | ahh, yes, I see lookin in the gallery a bit the long beds are all ND rather than AD, but I can't imagine it had anything to do w/ power, as the same engine powered all the trucks, right up to the biggest rigs, just a marketing/profitability thing I'd never noticed before - maybe cuz I'm not too keen on either AD's or stepsides long or short Bill | | | | | Joined: May 2003 Posts: 328 Shop Shark | | Shop Shark Joined: May 2003 Posts: 328 | Red58, as dave s stated, GMCs had different powerplants than Chevys. I don't think it was a marketing ploy. The fact is GMC used pressurized oiling while Chevy used splash oiling. Perhaps you should do more research to properly answer questions or dispute other's answers.
Phil
Never hold your farts in. They travel up your spine and into your brain...that is where crappy ideas come from.
| | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | GMCs used a better alloy in the engine blocks, too.
I keep hearing about these partially-enclosed 3/4 ton driveshafts. When did these stop? I can't remember seeing that setup on my three 3/4 and 1-ton trucks from '52-'55.1. I'll take a better look this weekend. | | | | | Joined: Jun 2005 Posts: 145 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 145 | GMCpanel wrote: "I keep hearing about these partially-enclosed 3/4 ton driveshafts. When did these stop?"
My '50, 3/4 ton has a closed driveline to a carrier bearing and then open from there to the differential. I have no idea when they stopped.
Kels
Half Ton Will Travel God bless America...One nation under God
| | | | | Joined: Dec 2004 Posts: 452 Member | | Member Joined: Dec 2004 Posts: 452 | Several people have said that the 3/4-tons only had 4-speed trannys, but the standard transmission for the AD 3/4-tons was the 3-on-the-tree, with the 4-speed as an option. The 1-tons had the 4-speed as standard.
The enclosed front driveshaft on the AD 3/4-tons ended with the '54 models. All of the AD 1-ton drivelines were fully open.
Curt ---- 1953 Chevy 6400, 1957 Chevy 2dr Sedan --"Mediocrity is easy, the good things take time"
| | | | | Joined: Jun 2000 Posts: 454 Shop Shark | | Shop Shark Joined: Jun 2000 Posts: 454 | Curt, you beat me to it.
Some of the confusion may be due to differences between the Chevy and GMC trucks. I cannot comment on the GMC, but Curt is dead on. The Chevy AD 3/4 tons had a three speed on the column as standard with the four speed a RPO (Regular Production Option).
On the driveline, if you don't believe us that the front was enclosed on the AD Chevy 3/4 tons, go read the Shop Manual, specifically page 4-52.
Jeff Nelson
| | | | | Joined: Jan 2004 Posts: 255 Member | | Member Joined: Jan 2004 Posts: 255 | I have a 48, 3/4 ton daily driver and a 51, 3/4 ton complete rolling chassis if anybody needs pictures of any of the components. The rolling chassis is nice if I need to see how something is put together without crawling under the 48. The 48 and 51 are similar except that the 48 has lever shocks compared to the tube shocks on the 51, and bendix brakes on the 51 as opposed to the Huck on the 48. Ralph | | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | OK, I think I get it now...my only 3/4-ton is a 55.1 Chevy. The 1-tons are 52 and 54 GMC panels. I simply never noticed the stuff in the shop manual about the partially-enclosed divelines. My bad. | | | | | Joined: Apr 2006 Posts: 2 Junior Member | | Junior Member Joined: Apr 2006 Posts: 2 | Can anyone point me to some good pictures of a '51 3/4 ton? I need to see the the hood emblems that were stock.
thanks so much, Frank | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Another interesting difference between the 1/2- and 3/4-ton trucks is the way the frame is designed. On a 1/2-ton Chevy the width of the frame inceases until just behind the rear axle. On the 3/4-ton the rails are parallel starting under the cab.
Canadian GMC's of the Advance Design/New Design era ran Chevy motors. I suspect that is part of the confusion above, since we have at least one Canadian in this dialog.
I too have never understood why GMC sold a long box 1/2-ton and Chevy did not. The suggestion that it has something to do with the better GMC motors doesn't make sense since as far as I know Chevy ran the same 216 in 3/4- and 1-ton trucks.
I suspect it was some marketing decision rather than one made based on some engineering issue.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | FYI:
SM420s were not available until the fifties ('53 or '54, IIRC). The four speed trannies that were available in that timeframe were of the "Coffee Grinder" variety.
The stanard tranny in 3/4 tons were three speeds. Many people went with a four speed, though. | | | | | Joined: Oct 2003 Posts: 363 Member | | Member Joined: Oct 2003 Posts: 363 | Originally posted by Brendan M: FYI:SM420s were not available until the fifties ('53 or '54, IIRC). The four speed trannies that were available in that timeframe were of the "Coffee Grinder" variety.
SM420s became available in 1947. For reference check the Novak page or just google SM420 1947. | | | | | Joined: Nov 2000 Posts: 1,966 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,966 | SM420's came out with the 48 model year.
Professional Novice
| | | | | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | Well, color me embarrassed.
I must have misuderstood my grandpa.
My apologies. | | |
