9 members (DadsFirstPickup, Guitplayer, 3800GUY, Woodcmiami, KCMongo, Shade Baby, 2-Ton, NorCal52Suburban, sron48),
138
Mod | | | Forums66 Topics128,049 Posts1,055,662 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 208 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 208 | Is there any way to repair hood springs. The back of my hood rids high insted of siting where it is supose to no matter how much adjusting I do. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | prolly not the springs - try closing the hood w/ the springs off, if it sits right, the problem is worn hinges - springs job is to make opening easy and hold it open, and they always exert a tension on the hinges so worn pins react to it that way - bad springs mean hood doesn't stay in the open position - repro springs aren't spendy and the repro hinges should be available, they are for other years
Bill | | |
