8 members (Peggy M, RAC1812, Otto Skorzeny, Bill Marlow, HandyAndy, GRNHydra, 49nut, 1 invisible), 238 guests, and 1 robot.
Topics128,087
Posts1,055,980
Members48,430
#184209 06/23/2005 11:48 PM
I used to have doors with the push button outside, then I bought doors with handles that turn down to open the doors.The fellow that sold me the doors told me I would need new clasps to go with that year of door and gave them with the doors.Problem ,the doors fit great ,but the clasp screw holes do not line up with the originals.Did he give me the wrong parts and can I cut the ends off both sets and weld the original ends onto the new clasps in order to make this work?Any suggestions for my 53 1/2 ton AD? Thanks in advance.
Lothar
The reason I did it is because my old doors were rusted out badly ,the glass broken,and the chrome pitted. So I figured everything else in them would be worn out too. The doors I found still had original paint and were mint including the chrome and glass.The price was also good ,$25.00 each,even the rubber seals around the doors and windows are excellent.The outside handles even still sit perfectly horizontal. It seemed like a slam dunk.Besides I had a set of stock finger gaurds for those type of doors and not the others.Also,I preferr just pulling the handle to open the door rather than pushing the button and then pulling, call me lazy.
KillerKnight - use whatever doors you want, its your truck! I have two trucks one set of each type of handles. I like the pull down type because they are old style.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
8
8 Offline
I wonder if the guy didn't give you the wrong strikers. They should be a direct bolt on replacement. My '51 had a '52 push-button door for years. The strikers mounted in the same place with no fuss. You may need to see about getting a set of used or repro strikers...
-Tim
'51 Chevy 3104 w/'56 235, 848 Head, HEI Dizzy, Corvette Cam, Split Manifold and Dual Carter YF's
must be the wrong strikers,I guess I'll just customize the strikers I got by cutting the 2 sets and welding the old ears on to the new strikers.Thanks people. Lothar
PS, did your friend sell his old truck Bill?
Lothar
No it is still in his garage. He has done nothing to it in all this time. I wish he would. He spent big bucks on an older Benz convert from your area actually. To me it is more his style than an old truck is. BTW my 53 is for sail (still, again).
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
Well I ended up making them out of the 2 sets I had, worked out well ,and they look stock. except for the grey paint. the doors lock.
