1 members (baldeagle),
96
Mod | | | Forums66 Topics128,037 Posts1,055,466 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 72 | I have a 53 5 window, and I once saw on a web site a flush mount gas cap that was located in the stock location on the cab. I can't seem to find it again. Does anybody know who may sell this gas cap or where the web site might be?
They looked really cool and it saved all the work of re-locatign the tank.
Thanks, Dan
If you didn’t skin a knuckle while you were working on your truck, you weren’t working hard enough! 53 5window 1/2 ton54 3window 1/2 ton
| | | | | Joined: Oct 2004 Posts: 128 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 128 | Hi, Try haganstreetrods.com they offer a few different flush mount fuel doors. I'm sure they offer something you could make work. A little pricey, but looks like quality stuff. John | | | | | Joined: Apr 2005 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 72 | John,
Thanks for the information. I will let you know what I find out.
Dan
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | airride technologies has one called cool cap, pricey 60.00 for cap and 60.00 for flanger to make it flush. just finished putting mine on my fender. go to my community webshots and look at 0112 to see if that is what you want. www.ridetech.com RON
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Sep 2004 Posts: 120 Member | | Member Joined: Sep 2004 Posts: 120 | It may seem that moving the gas tank is alot of trouble, but your interior is always going to smell like gas if you don't move it | | | | | Joined: Apr 2005 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 72 | We B Old,
Since you have had one in hand, do you think that gas cap would work in the stock hole position on the cab?
gmckustom,
Right now I don't want to go through the work and expense to move the tank to the back. I don't want to move fuel lines, new filler set up, mount full cap/door in the bed or fender? Do you need to install a fuel pump if you bringing the gas from the rear?
I do like the added room that moving the gas tank would create (speakers, tools, a place to put a coat, ect...)
Right now I just want to clean up the look of the filler tube and cap on the cab.
As usual, thanks for all the great information, imput, and ideas guys.
Dan
| | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | If your cab smells like gas, your gas tank is either leaking, or you spilled some down the filler neck.
No gas tank should smell like gas, regardless of where it is.
From another thread on this board, it seems the biggest reason folks move the tank is to add space for storage in the cab, especially in the AD trucks with the tank behind the seat.
| | | | | Joined: Sep 2004 Posts: 148 Member | | Member Joined: Sep 2004 Posts: 148 | i am moving mine for safety reasons
2003 ford lightning 1959 chevy 36
| | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | What are the safety reasons to move the tank out of the cab?
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | If it leaks, you get used to it. It really shouldn't leak though. | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | 53fivewindow, just went out and took a good look at the old mounting place, it looks like the cap would fit with or without the flanger. i would suggest you try it without flanging. the instruction say it would work on a slightly crowned panel. RON
| | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | Originally posted by 1-ton of fun: i am moving mine for safety reasons If it's leakin' i'd guess moving it (or replacing it) would be a good idea! Folks talk about moving their tanks for a few reasons.. to add space in the cab, or to increase the fuel capacity (bigger tank under the bed) but i've not heard any strong argument to suggest moving a tank (that's in good condition) would make the vehicle any more safe.
| | | | | Joined: Apr 2005 Posts: 72 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 72 | WE b OLD,
Thank you for the information and your time. I will buy it without the flange and see how it works. I will let you know what the result is and send you a picture when I complete it. It may be a while because my cab is off and it needs some work and some paint. No need to put a new cap on a work in progress (horse before the cart saying).
Talk to you soon.
Dan
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | DAN, let me know if you want to try the flanger we might be able to work out something just for the shipping cost back and forth. RON
