4 members (Peggy M, Otto Skorzeny, klhansen, farmallb), 107 guests, and 2 robots.
Topics128,041
Posts1,055,487
Members48,424
#184104 06/21/2005 3:20 PM
I have a 53 5 window, and I once saw on a web site a flush mount gas cap that was located in the stock location on the cab. I can't seem to find it again. Does anybody know who may sell this gas cap or where the web site might be?
They looked really cool and it saved all the work of re-locatign the tank.
Dan
If you didn’t skin a knuckle while you were working on your truck, you weren’t working hard enough!
53 5window 1/2 ton
54 3window 1/2 ton
#184105 06/21/2005 6:49 PM
Hi, Try haganstreetrods.com they offer a few different flush mount fuel doors. I'm sure they offer something you could make work. A little pricey, but looks like quality stuff. John
#184106 06/21/2005 10:36 PM
John,
Thanks for the information. I will let you know what I find out.
Dan
53 5window 1/2 ton
54 3window 1/2 ton
#184107 06/22/2005 1:56 AM
airride technologies has one called cool cap, pricey 60.00 for cap and 60.00 for flanger to make it flush. just finished putting mine on my fender. go to my community webshots and look at 0112 to see if that is what you want. www.ridetech.com RON
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
#184108 06/22/2005 2:33 AM
It may seem that moving the gas tank is alot of trouble, but your interior is always going to smell like gas if you don't move it
#184109 06/22/2005 2:41 PM
We B Old,
Since you have had one in hand, do you think that gas cap would work in the stock hole position on the cab?
gmckustom,
Right now I don't want to go through the work and expense to move the tank to the back. I don't want to move fuel lines, new filler set up, mount full cap/door in the bed or fender? Do you need to install a fuel pump if you bringing the gas from the rear?
I do like the added room that moving the gas tank would create (speakers, tools, a place to put a coat, ect...)
Right now I just want to clean up the look of the filler tube and cap on the cab.
As usual, thanks for all the great information, imput, and ideas guys.
Dan
53 5window 1/2 ton
54 3window 1/2 ton
#184110 06/22/2005 3:10 PM
If your cab smells like gas, your gas tank is either leaking, or you spilled some down the filler neck.
No gas tank should smell like gas, regardless of where it is.
From another thread on this board, it seems the biggest reason folks move the tank is to add space for storage in the cab, especially in the AD trucks with the tank behind the seat.
#184111 06/22/2005 4:08 PM
1 Offline
i am moving mine for safety reasons
2003 ford lightning
1959 chevy 36
#184112 06/22/2005 5:39 PM
What are the safety reasons to move the tank out of the cab?
Dennis
#184113 06/23/2005 3:19 AM
Anonymous
Unregistered
Anonymous
Unregistered
If it leaks, you get used to it. It really shouldn't leak though.
#184114 06/23/2005 3:49 AM
53fivewindow, just went out and took a good look at the old mounting place, it looks like the cap would fit with or without the flanger. i would suggest you try it without flanging. the instruction say it would work on a slightly crowned panel. RON
2017 Buick Encore
See more pix
#184115 06/23/2005 7:06 AM
Quote
If it's leakin' i'd guess moving it (or replacing it) would be a good idea!
Folks talk about moving their tanks for a few reasons.. to add space in the cab, or to increase the fuel capacity (bigger tank under the bed) but i've not heard any strong argument to suggest moving a tank (that's in good condition) would make the vehicle any more safe.
#184116 06/23/2005 3:38 PM
WE b OLD,
Thank you for the information and your time. I will buy it without the flange and see how it works. I will let you know what the result is and send you a picture when I complete it. It may be a while because my cab is off and it needs some work and some paint. No need to put a new cap on a work in progress (horse before the cart saying).
Talk to you soon.
Dan
53 5window 1/2 ton
54 3window 1/2 ton
#184117 06/24/2005 5:25 PM
DAN, let me know if you want to try the flanger we might be able to work out something just for the shipping cost back and forth. RON
2017 Buick Encore
See more pix
