8 members (Gdads51, Otto Skorzeny, warlock, RoadsScholar, Ponchogl, 55shaker, k2handyman, 5 Window 9434),
104
Mod | | | Forums66 Topics128,048 Posts1,055,626 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2004 Posts: 255 Member | | Member Joined: Jan 2004 Posts: 255 | Hi All, I finally had a day to work on my 48 - 3/4 ton daily driver. One of my front tires is to the point that it needs replacing. I bought some new tires at the local tire shop and set to installing them. I decided to go ahead and clean and paint the wheels so this slowed the process down. I have been running 205-15's on the front and 235-15,s on the back. I bought 215-15's to replace the front tires and thats where I started. I got one completely sandblasted and painted and just got part way through the other due to a compressor leak. Since I only had one new tire mounted and its bigger than the other side, I still didnt get the probelm fixed. I did try an experiment with the rear wheels. I had a pair of mounted 9.50 - 16.5, 8-hole wheels on my welder trailer and I have always been curious if they would work on my truck. They do. They are a lot bigger than the tires I took off and they look funny, but I was encouraged enough to go ahead and add the hubcap clips so I could mount my original hubcaps. These taller and wider tires really improved my top speed (4.57:1 gears) and I am getting used to the look. I still need to finish painting and mounting the other front tire, but for the meantime, I am still driving her. Ralph | | | | | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | Thats the most important thing. Whenever I'm doing small jobs on mine, I'll sometimes go to the junkyard, buy a used piece I already have on the truck and clean and paint it so I don't have any down time. Then I swap the old one for something new I need. Works great. | | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | It might be worth it to hit the local junkyards and find a 4.11 rear end - not as big of an improvement as if you were driving a 1-ton with the 5.14 gears, but it should give a bit of help. | | | | | Joined: Jan 2004 Posts: 255 Member | | Member Joined: Jan 2004 Posts: 255 | Hey GMC Panel, We dont have any local junkyards anymore. I have to go to Amarillo. Phil 1953GMC said if he had time he would do some looking around for me. I hear that those rear ends are getting scarce. Shipwright, I have a complete 3/4 ton rolling chassis from a 51 that I will use for parts and also 2 half tons without engines. My next project is to blast and paint one of the 1/2 ton chassis, do brakes, new rear end, 292 and T-5, and then move my 3/4 ton body over to the 1/2 ton chassis. I have everything I need except the T-5, a shop, and the time. Ralph | | | | | Joined: May 2003 Posts: 328 Shop Shark | | Shop Shark Joined: May 2003 Posts: 328 | Ralph, My dad has a T-5 in his shop in Midland. I am going there Thursday. Let me know if I need to bring it back.
Phil
Never hold your farts in. They travel up your spine and into your brain...that is where crappy ideas come from.
| | | | | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | I went to the oldest tranny shop in town and bought a rebuilt T5 with V8 gears. (out of a Camaro) He installed the s-10 tailshaft on it for me too. I was expensive ($550) but worth it. Having to wrangle all the right parts togather just makes for more down time. IMHO Sounds like its gonna be a sweet setup. Good Luck | | | | | Joined: Jan 2004 Posts: 255 Member | | Member Joined: Jan 2004 Posts: 255 | Hey Phil, Thanks for the offer, but I dont have the money or a place to put it right now. I am still trying to get some of the local bolters to take a road trip for the next cruise night. It would be nice to have 3 stovebolts going at once, my original, Jr's 50's style and Shelly's restored truck. I will keep you updated as I hear something. Ralph | | |
