| | | Forums66 Topics128,081 Posts1,056,078 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2004 Posts: 235 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2004 Posts: 235 | Ok guys I've just started on replacing my king pins. I've got one brake backing plate off ok but the other is proving a problem. The inner bearing won't budge and I was wondering if I'll need to use a puller on it or if I could use a punch from behind to ease the bearing forward on the shaft.
Appreciate any suggestions.
Bob | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I used heat to remove mine but I replaced the bearings. If you are going to use it again I wouldn't heat it. It will probably come off tapping on it with a brass punch if you can find a place to tap on. | | | | | Joined: Oct 2004 Posts: 235 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2004 Posts: 235 | Thanks Cletis. It looks pretty good so I will be using it again. Thanks for the help
Bob | | |
