5 members (rfs56trk, JW51, Bill Hanlon, Cosmo, 1 invisible), 105 guests, and 3 robots.
Topics128,080
Posts1,055,956
Members48,430
#183688 06/13/2005 9:36 AM
Ok guys I've just started on replacing my king pins. I've got one brake backing plate off ok but the other is proving a problem. The inner bearing won't budge and I was wondering if I'll need to use a puller on it or if I could use a punch from behind to ease the bearing forward on the shaft.
Appreciate any suggestions.
Bob
#183689 06/13/2005 5:54 PM
I used heat to remove mine but I replaced the bearings. If you are going to use it again I wouldn't heat it. It will probably come off tapping on it with a brass punch if you can find a place to tap on.
#183690 06/14/2005 12:28 AM
Thanks Cletis. It looks pretty good so I will be using it again. Thanks for the help
Bob
