3 members (MNSmith, Otto Skorzeny, 1 invisible), 155 guests, and 3 robots.
Topics128,088
Posts1,056,114
Members48,434
#183611 06/12/2005 2:23 PM
Apprentice
Apprentice
Does anyone sell brake line kits for 65 shortbed 4x4? I see them for all the 2wd but not 4wd
#183612 06/13/2005 12:23 AM
I think the steel lines would be the same between the two but the rubber hose going to the diff. to the body would need to be longer for the 4x4.
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#183613 06/13/2005 11:33 PM
Apprentice
Apprentice
Sub65,
If your are running the stock suspension the rear brake hose is approximately 21" long. NAPA # is 25629. Front brake hose is approximately 24" long (2 req.) NAPA #34466.
As for the steel lines I took my old ones and went to a brake shop and ordered them about an inch longer so that I could bend them to fit a little better around the diff cover and u-bolts.
[img]http://mywebpage.netscape.com/wck10s/images/rearend.jpg[/img]
Hope that helps,
64K10
