| | | Forums66 Topics128,089 Posts1,056,141 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 13 Apprentice | | Apprentice Joined: Mar 2005 Posts: 13 | Does anyone sell brake line kits for 65 shortbed 4x4? I see them for all the 2wd but not 4wd | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I think the steel lines would be the same between the two but the rubber hose going to the diff. to the body would need to be longer for the 4x4. Scott | | | | | Joined: Dec 2001 Posts: 21 Apprentice | | Apprentice Joined: Dec 2001 Posts: 21 | Sub65, If your are running the stock suspension the rear brake hose is approximately 21" long. NAPA # is 25629. Front brake hose is approximately 24" long (2 req.) NAPA #34466. As for the steel lines I took my old ones and went to a brake shop and ordered them about an inch longer so that I could bend them to fit a little better around the diff cover and u-bolts. [img] http://mywebpage.netscape.com/wck10s/images/rearend.jpg[/img] Hope that helps,
64K10
