4 members (JW51, dt235sd, Otto Skorzeny, 1 invisible), 103 guests, and 1 robot.
Topics128,062
Posts1,055,854
Members48,428
#183609 06/12/2005 12:35 PM
I own an 18' auto hauler trailer, which is coming due for a paint job. The deck of the trailer is diamond plate metal. Am considering having the deck coated with the same material used in spray-in bed liners. Thought this would give the deck a hard, non skid surface, and increase the overall life of the trailer. Anyone out there done this yet? Comments?
#183610 06/12/2005 3:14 PM
Couldn't hurt! It's got to be less slick than a painted steel surface, so you should have better adhesion and less slippage when you drive a car up onto it. Let us know what you do.
Pessimist - Sees glass as half-empty. Optimist - Sees glass as half-full. Gov't- Sees glass and takes it from you because you have a glass.
Political Correctness: A philosophical belief system bereft of common sense and logic, that supports and rewards ignorance and stupidity.
