6 members (Gdads51, Otto Skorzeny, 3800GUY, Swami29, Youngin' Tut 59, 1 invisible), 97 guests, and 2 robots.
Topics128,114
Posts1,056,604
Members48,448
#183573 06/11/2005 10:53 PM
well i have a 61 chevy apache 1/2 ton shortbed stepside.. and today i primered teh front end minus hood.. (left/right front fenders and watever the front peice is called.. as progress goes i wonder.. should i paint it or leave it taht way.. its dark gray primer and i liek the color but im not sure.. any opinions would be nice
Mike,
It depends on how long it will be before you paint the whole truck. It is OK to leave primer, but if it is going to be a while before you paint the whole truck, you should follow up with a primer-sealant.
If you do a second-rate paint job on each panel, you'll increase the amount of prep work you'll have to do before the final paint job, and re-prime.
That's what I was taught, anyway . . .
Good luck,
~ Kimberly
My '54 ... and my '63 and a '59 F100
P.S. You might want to post this same question in the Paint and Body forum - those guys are a lot smarter than me!
~ Kimberly
