9 members (WICruiser, Youngin' Tut 59, Rick Brown, Gdads51, Hotrod Lincoln, KEVINSKI, 3800GUY, TUTS 59, 1 invisible),
106
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,116 Posts1,056,589 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2005 Posts: 95 Member | | Member Joined: Feb 2005 Posts: 95 | well i have a 61 chevy apache 1/2 ton shortbed stepside.. and today i primered teh front end minus hood.. (left/right front fenders and watever the front peice is called.. as progress goes i wonder.. should i paint it or leave it taht way.. its dark gray primer and i liek the color but im not sure.. any opinions would be nice | | | | | Joined: Feb 2005 Posts: 355 Member | | Member Joined: Feb 2005 Posts: 355 | Mike, It depends on how long it will be before you paint the whole truck. It is OK to leave primer, but if it is going to be a while before you paint the whole truck, you should follow up with a primer-sealant.
If you do a second-rate paint job on each panel, you'll increase the amount of prep work you'll have to do before the final paint job, and re-prime.
That's what I was taught, anyway . . .
Good luck, K | | | | | Joined: Feb 2005 Posts: 355 Member | | Member Joined: Feb 2005 Posts: 355 | P.S. You might want to post this same question in the Paint and Body forum - those guys are a lot smarter than me! K | | |
