3 members (BC59, cmayna, Peggy M),
144
Mod | | | Forums66 Topics128,095 Posts1,056,475 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 734 Shop Shark | | Shop Shark Joined: Mar 2004 Posts: 734 | Finally getting around to doing the back brakes. The manual calls for packing the bearings which I don't get. Isn't all that area filled with gear oil on a C20? -David | | | | | Joined: Apr 2000 Posts: 499 'Bolter | | 'Bolter Joined: Apr 2000 Posts: 499 | Yes. Yes. Just going from memory, I think most of the axle rebuild material says grease them so that they are not running dry until any of the gear oil makes its way out there. Depending on the hubs, you may not have to pull them to take the drums off. See if you have two big slotted screw heads that are flush with the surface, between a couple of the wheel studs.
'67 GMC 3/4 292 4spd
| | | | | Joined: Mar 2004 Posts: 734 Shop Shark | | Shop Shark Joined: Mar 2004 Posts: 734 | Thanks Richard. I didn't remove the bearings. I greased 'em and used compressed air to pack it in there. All the stuff was in really good shape including the shoes and cylinders. Doesn't surprise me as the previous owner obviously did a lot of work on the rear suspension and axle. Those back drums are heavy! -David | | |
