4 members (Gdads51, Gib70, tclederman, Gray_Ghost), 158 guests, and 3 robots.
Topics128,078
Posts1,056,021
Members48,433
#183471 06/10/2005 5:41 AM
id like to get 15 inch centerlines for my 52 1/2 ton someone told me a long while back toyota truck rims will fit anybody know if this is correct thanks for help
#183472 06/10/2005 6:03 AM
32fire2,
I just posted about this.
Do a search on
Alum Rims
Aaron
#183473 06/10/2005 6:18 AM
did the serch came back no resalts
#183474 06/10/2005 6:24 AM
were bouts did you post i cant find it thanks
#183475 06/10/2005 6:42 AM
try this ...
type in chev235 in the following field:
Member Number or Public Display Name
#183476 06/10/2005 7:05 AM
ive used the six lug rims from a nissan on my 53 1\2 .i think all the jap scrap have the same 6-lug pattern.toyota landcruiser fit also
#183477 06/10/2005 7:52 AM
Seems to me the only problem might be the back spacing for some of the factory steel wheels causing contact with the end of the tie rod. The aftermarket wouldn't want to spend the money necessary to make two separate wheels just for a little clearance issue,so they'd make the same wheel with enough clearance to fit pretty much anything with a 6 lug pattern. (except the old Dodge and Cornbinder 3/4 and 1 tonners) More applications covered with the same part #.
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
#183478 06/11/2005 1:53 PM
V
V Offline
almost any japanese 6 bolt wheel will fit on your truck the newer dodge dakota 6 bolt wheels WILL NOT fit the bolt pattern is smaller.Isuzu pick ups usually have a larger center hole than Nissan/toyota but bolt pattern is the same hope this helps
