0 members (),
139
7
Mod | | | Forums66 Topics128,077 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | id like to get 15 inch centerlines for my 52 1/2 ton someone told me a long while back toyota truck rims will fit anybody know if this is correct thanks for help | | | | | Joined: May 2004 Posts: 204 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 204 | 32fire2,
I just posted about this. Do a search on Alum Rims
Aaron | | | | | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | did the serch came back no resalts | | | | | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | were bouts did you post i cant find it thanks | | | | | Joined: May 2004 Posts: 204 Wrench Fetcher | | Wrench Fetcher Joined: May 2004 Posts: 204 | try this ... type in chev235 in the following field: Member Number or Public Display Name | | | | | Joined: Mar 2005 Posts: 6 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 6 | ive used the six lug rims from a nissan on my 53 1\2 .i think all the jap scrap have the same 6-lug pattern.toyota landcruiser fit also | | | | | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | Seems to me the only problem might be the back spacing for some of the factory steel wheels causing contact with the end of the tie rod. The aftermarket wouldn't want to spend the money necessary to make two separate wheels just for a little clearance issue,so they'd make the same wheel with enough clearance to fit pretty much anything with a 6 lug pattern. (except the old Dodge and Cornbinder 3/4 and 1 tonners) More applications covered with the same part #. | | | | | Joined: Jun 2005 Posts: 221 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 221 | almost any japanese 6 bolt wheel will fit on your truck the newer dodge dakota 6 bolt wheels WILL NOT fit the bolt pattern is smaller.Isuzu pick ups usually have a larger center hole than Nissan/toyota but bolt pattern is the same hope this helps | | |
