1 members (texczech),
51
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#18331 05/16/2004 4:41 AM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I found a 68 C-50, has a small block, truck is a LCF so I can't get casting #'s(back of engine nearly against firewall), but stamped in front of pass head is FI207D. Anyone have a clue as to engine size? Brian | | |
#18332 05/16/2004 5:24 PM | Joined: Feb 2004 Posts: 29,747 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,747 | Aording to my Chilton repair manuals, a "D" suffix letter indicates the engine is a 1958-64 283 cubic inch. I don't have a letter designation in the truck manual that covers the 68 C-50, buit the 283 is not listed as an engine option for that year model. Jerry
#18333 05/16/2004 5:48 PM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | Looking at a GM parts manual, the 327 was the standard V-8 for the C-50, besides the 292 6. The 68 truck 327 numbers starts with Y, in fact no truck small blocks from 56-70 start with an F. | | |
#18334 05/16/2004 6:38 PM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Guess I'll get it, I can tell what it is after it is out. I would like a 327. It looks original, has draft tube, script valve covers, front mounting. Thanks, Brian | | |
#18335 02/23/2006 7:02 PM | Joined: Oct 2002 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2002 Posts: 69 | old post but i found a 68 c-50 or 60 that im debating on buying for 300 it runs good and new rockers but no bed and is real short wheelbase, it has the original 2 bbl 327 in it,
jut unsure if i need to get it or not, seems cheap but im just unsure
68 would be at least a 327 or better, 366, 427 truck deck, could be several different engines, but if its a sbc gas engine thne would be 327 factory, 68-up anyways
good luck
Randy the easter wabbit ! -here to help fellow enthusiasts as best as possible  parting some vehicles, 54 ford truck 57, chevy 210, 69 fairlane coupe HT and others, | | |
#18336 02/24/2006 4:07 AM | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | C50s also came with 292s. That's where the engine in my 1 ton came from (actually a 69 model). | | |
