0 members (),
110
Mod | | | Forums66 Topics128,183 Posts1,057,264 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2004 Posts: 8 Junior Member | | Junior Member Joined: Nov 2004 Posts: 8 | Hello everyone, Just joined the Stovebolt. Trying to get more info on the 1955 Chevy Pickup Series One I just bought. I have been to several web pages, plugged in my VIN ID and get different results. Can anyone tell me more or any info on the following VIN?
J550006188? This is on the Title and the inter door.
Thansks Mike | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Welcome to the Stovebolt Mike.
I don't completely trust vin numbers anymore. A '55 1st should have a curved windshield and an open driveline (first year on half-tons). It should also have the '54-55 only grill, push button door handles and wing windows.
I believe J means 3/4-ton and 55 means 1955. It should have a wheel base of 125 inches and have 8-lug hubs if its a 3/4.
I believe the 4th character will tell you where it was made, but don't recall the code for that part...
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Apr 2004 Posts: 543 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 543 | Also, you have the 6,188th truck off that assembly line (006188).
Pessimist - Sees glass as half-empty. Optimist - Sees glass as half-full. Gov't- Sees glass and takes it from you because you have a glass. Political Correctness: A philosophical belief system bereft of common sense and logic, that supports and rewards ignorance and stupidity.
| | | | | Joined: Nov 2004 Posts: 8 Junior Member | | Junior Member Joined: Nov 2004 Posts: 8 | Hi, thanks for the info, I will have to check out all the parts, as the truck is in about a thousand parts in boxes. The owner started the restoration and couldn't finish it. Everything is in good shape, I just need to figure out what it is first. I will check the hubs first, but I guess it could be a different rear and front end also. No glass in the front windshield.
Mike | | | | | Joined: Feb 2002 Posts: 2,896 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,896 | OldYeller55, poke around in the gallery... click the link at the top of the page. There are several trucks like yours up there...
as for the window glass - the '47-'53 had two piece glass with a post in the center - '54-'55 had a whole piece of glass... so if yer windshield is out, it shoudl be one big happy roundish/oval hole...
-W | | |
