2 members (dt235sd, carbking),
103
Mod | | | Forums66 Topics128,266 Posts1,058,368 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2005 Posts: 95 Member | | Member Joined: Feb 2005 Posts: 95 | i just want to run one flowmaster out the back and i was curious if this will affect the engine in anyway | | | | | Joined: Oct 2004 Posts: 209 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 209 | I dont know. I have one running out of the left and one running out of the right side of my 64. 350 v-8 in it. I dont know if that would help you in any way.
Stovebolt-It is painted
| | | | | Joined: Apr 2004 Posts: 543 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 543 | Check your fuel/air mixture after you install the muffler to make sure you're not running lean afterwards...that's about it!
Pessimist - Sees glass as half-empty. Optimist - Sees glass as half-full. Gov't- Sees glass and takes it from you because you have a glass. Political Correctness: A philosophical belief system bereft of common sense and logic, that supports and rewards ignorance and stupidity.
| | | | | Joined: Oct 2003 Posts: 445 Shop Shark | | Shop Shark Joined: Oct 2003 Posts: 445 |
dan-pa
| | | | | Joined: Apr 2005 Posts: 28 Junior Member | | Junior Member Joined: Apr 2005 Posts: 28 | If you get Flowmasters, I'd recommend the three-chamber over the two chamber. The two chambers are really loud for something you're going to drive regularly on the street. | | | | | Joined: Dec 2003 Posts: 510 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 510 | I run split headers and Cherry Bombs with exits in front of the rear wheels in my 64 with 292 and AFB 4-barrel. I love the sound. Yeah, it raps a bit if ya wind it out and back off the gas, but then that's why I put the Cherry Bombs on it. | | | | | Joined: Jan 2000 Posts: 175 Shop Shark | | Shop Shark Joined: Jan 2000 Posts: 175 | This is what I run on my '97 GMC pickup (5.7). Moroso Spiral flow race mufflers http://www.moroso.com/catalog/categorydisplay.asp?CatCode=35001 No packing to blow out and they sound good.
Gravity - It's not just a good idea, it's the law.
| | | | | Joined: Apr 2005 Posts: 113 Member | | Member Joined: Apr 2005 Posts: 113 | I have one on my 235 and it sounds pretty decent. It's a little loud when I lay into it but it has a real nice idle to it. | | | | | Joined: Oct 2004 Posts: 96 Member | | Member Joined: Oct 2004 Posts: 96 | What series flowmasters would you run. Lots of people run the 40 series but there are 2 kinds The original Flow and the delta flow? Im really leaning to the split manifold with Flowmasters on it. KCMONGO's truck has the sound that i want my truck to have. | | | | | Joined: Feb 2005 Posts: 95 Member | | Member Joined: Feb 2005 Posts: 95 | wow thanks everyone.. id liek to do headers down the line.. but not now.. (money is short)
so which is a deeper thoatyier tone.. the cherry bombs or the flowmasters | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | Another one to consider is the magnaflow muffler.They sound more like the old glasspacks. | | | | | Joined: May 2001 Posts: 47 Member | | Member Joined: May 2001 Posts: 47 | Save your money, run straight pipes. I have two of the old smitty's still in the box. Just can't part with the straight pipes...even on my v/8..some of the club memebers are cutting OFF their mufflers, even on any v/6 engines. A little loud but man it sounds good. They call my 37 the little obnoxious pickup. Ha, they love it!!! | | |
