1 members (delky), 74 guests, and 3 robots.
Topics128,037
Posts1,055,466
Members48,422
#182171 04/18/2005 4:08 PM
Got my truck running this weekend. Had a problem with oiling the rockers. I just groung a groove through the threads on the center pass head bolt. I think my engine guy installed the wrong head gasket and it blocked off oil supply to rockers. Anyway that solved the problem. I got 35 lbs oil prssure and the cam I got gives it a little rumpy idle wink The 5 speed works fantastic but I think my rear end gear (3.73) is a little steep. I think a 4.11 would be perfect if anyone decides to do this same swap. The truck sits a little tilted as I removed some leaf springs to get the ride height down a little. No biggie I just need to remove one more leaf from the pass side front and I think it will sit right. Had to move radiator forward even with the short water pump conversion :mad: and had to trim the fan to clear the bolt I installed to hold the harmonic balancer on tight. All and all I'm very pleased with the result. My turning radius stinks though. Need to investigate that. Thanks fot all the help everyone. I'll post more pics on my site soon.
#182172 04/18/2005 4:19 PM
Congratulations!
53 3100
1929 Ford Roadster Pickup
1934 Ford Pickup
68 Plymouth Satellite RR Clone 2 Door
My Fleet
#182173 04/18/2005 4:19 PM
Bull, what engine do you have, you stated that the 3:73 rear gear was a little steep, and needed a 4:11, when you mean steep, do you mean you need a lower gear...you aren't confused, I am,,,thanks,,looked at your site,nice truck,,,Fred
Redryder pix
My Hotrod
#182174 04/18/2005 11:46 PM
I got a 235 bored 40 over with a howards cam. I think it might have too much cam. The power is a little higher on the RPM band than I need. When I finish rebuilding front end (drag link and tie rod) I'll get it back out on the highway and see what it will do. It's a little scary doing 75 with stock steering. Brakes work great. I put CCP's front disc setup on it with a new dual master cyl. What would cause my turning radius to get worse? I don't think it was this bad before the teardown.
