2 members (Ole49GMC, Hush),
74
Mod | | | Forums66 Topics128,169 Posts1,057,102 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#18117 05/29/2002 2:22 AM | Joined: Jan 2001 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 687 | | | |
#18118 05/29/2002 4:08 AM | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 |
54 3100 with 235 62 flatbed dump C60 with 261
#18119 05/29/2002 11:25 AM | Joined: Aug 2001 Posts: 35 Member | | Member Joined: Aug 2001 Posts: 35 | Still, $10 for a stovebolt engine ain't bad! If'n I's in Michigan, I'd give it'a lookin over. | | |
#18120 05/29/2002 11:43 AM | Joined: Jun 2000 Posts: 738 Shop Shark | | Shop Shark Joined: Jun 2000 Posts: 738 | That is how a seller sucks you in. Putting the price in for 10.00 got your attention. There's lots of time left. The only advantage that you guys have, is that they listed it as a 302, and if your looking for a 270 you would miss it maybe  Good luck!! | | |
#18121 05/29/2002 8:09 PM | Joined: Apr 2002 Posts: 146 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2002 Posts: 146 | Hey stay off ebay; thats where I get my parts cheep. Kidding Watch for reserves. He may have started at $10 but has a hi $ reserve.
if it dosen't need fixed, break it
#18122 05/29/2002 8:24 PM | Joined: May 2002 Posts: 44 'Bolter | | 'Bolter Joined: May 2002 Posts: 44 | No reserve posted on this one!!!!! Bid on!!!
"The Operation of GMC trucks is normally smooth and steady, with no loud rattling, knocking or unusual noises. A good driver will quickly become accustomed to driving a GMC truck and will get the feel of his vehicle regardless of his engineering knowledge."-TM10-1563
#18123 05/30/2002 9:41 AM | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | Hey! I'm bidding, I'm close (sorta). First bid went to $50 first try!  Tried again and now it's where I'm at! Must be out of big truck with the filter on it like that. How do you folks know it's a 270? Wish I could see if it has double or triple pulleys on it. Should say size on stamping if I e'mailed seller, I guess.
G.L. Grumpy's Old Iron Ranch Huntington, IN 46750
MM R tractor, Speedex and Power King tractors
#18124 05/30/2002 12:50 PM | Joined: Nov 2000 Posts: 427 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 427 | Wait a minute!
Is that GL "I hate eBay" Perry bidding on that motor?
Hmmmmmmmm. Must be a love/hate relationship!
Hope one of "our" people get that motor. I have been drooling over and admiring all the 302s on Inliners site and they are pretty impressive.
Good luck GL. You'll hate eBay even more before this ones over! LOL | | |
#18125 05/30/2002 3:21 PM | Joined: May 2002 Posts: 44 'Bolter | | 'Bolter Joined: May 2002 Posts: 44 | Looks like the harmonic balancer on the front is a single pulley and might be for a 7/8" belt. As you maybe noticed, the water pump is missing off the front. The valve cover has the hole just in front of the GMC logo for the PCV hookup and the oil filler just behind the filter has the oil bath filter for the PCV system. From the size of the filter housing I think your right about it coming out of a larger truck. The larger capacity filter was needed for such things as compressors and the larger hydromatics as the oil was run through these different components. Good candidate for a full flow conversion anyways
#18126 05/30/2002 3:47 PM | Joined: May 2002 Posts: 44 'Bolter | | 'Bolter Joined: May 2002 Posts: 44 | Here is the number from the distributor flange: 270290306.
#18127 05/30/2002 3:49 PM | Joined: Jan 2000 Posts: 206 Member | | Member Joined: Jan 2000 Posts: 206 | The seller added a note stating that it was a 270 | | |
#18128 05/30/2002 5:54 PM | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | None of you guys can read. The guy added that he found out it is a 270 and he also mentions it did not come out of a truck but is mounted on a frame and it was originally for some industrial use.
#18129 05/30/2002 6:30 PM | Joined: May 2002 Posts: 44 'Bolter | | 'Bolter Joined: May 2002 Posts: 44 | Sorry 'bout that Tony. Guess I better go back to grade school and learn all that readin' stuff over again. I did't see the part in his description where "he also mentions it did not come out of a truck". That stand sure don't look like what it was monted in for the industrial use. Maybe it came out of an "industrial" truck?................hmmmmmmmmmmmmmmm.
#18130 05/30/2002 11:56 PM | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | It says: "was used in industrial application and is mounted on a stand. Typical application would be GMC 2 1/2 ton military truck" I guess it could be an industrial military truck. I thought he meant, it is normally found in a truck, but this one was used in an industrial application.
#18131 05/31/2002 10:07 AM | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | I wrote guy and he says starts # with 270 and he ADDED the note later about size. The water pump and gen are laying in picture and he said all would go with, wasn't sure on pulleys, belts or fan, was gonna check. It's his brother's engine. I can't get on to check for sale process as ebay has shut-down for maintainance on early Fri mornings, Sheesh! That's when I'm on here, early AM!
#18132 05/31/2002 11:27 AM | Joined: Jun 2000 Posts: 738 Shop Shark | | Shop Shark Joined: Jun 2000 Posts: 738 | GL, Don't have a COW. There still is 5 days left. You have to learn to have PATIENCE!! Besides, ebay was working at 5:45 this morning(FRIDAY) must be they didn't have too much maintainance to do. It will be there! You still are high bidder..... Mr. Ebay hater! 61.00 I hope you get it. Tony and I bought a 261 on ebay. Had a great time picking it up. You meet the nicest people. Good Luck! | | |
#18133 06/02/2002 10:44 AM | Joined: Jun 2000 Posts: 738 Shop Shark | | Shop Shark Joined: Jun 2000 Posts: 738 | It's still looking good for you GL!!! Just a few days left!! | | |
#18134 06/03/2002 7:21 PM | Joined: Feb 2001 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2001 Posts: 92 | I wonder what GL would pay to keep the rest of us 270 owners from bidding? I really am in need of one, mine is in the shop and looks like the block will have to be stitched, ouch. If the call comes from the shop in the near future I may have to go up against ya GL. No hard feelings
Whats down in the well comes up in the bucket, so watch who's KoolAid you drink.
#18135 06/06/2002 9:19 AM | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | Well, looks like I won! Suprise!  I bet it's junk.  Now, gotta drive 3hrs North to get. Hope he has a way to lift on my flatbed! More stuff for my overstuffed garage now! Gonna be comin' to my Old Iron Home ranch soon!
#18136 06/06/2002 10:55 AM | Joined: Jun 2000 Posts: 738 Shop Shark | | Shop Shark Joined: Jun 2000 Posts: 738 | Great!!! You got it. ROAD TRIP! | | |
#18137 06/06/2002 1:41 PM | Joined: Jan 2001 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 687 | GL, How much do I get in commission for the hookup. Just kidding; but a few spare performance parts for the 292 I'm building would be nice. Congratulations! -ftyler | | |
#18138 06/10/2002 4:25 AM | Joined: Feb 2000 Posts: 587 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 587 | Got it! Took all day, I'm tired! 225 miles up and 255 back a slower road as my truck was getting warm on the highway. Slow way was prettier too! I hate Interstates! His neighbor has an MM M-5 tractor, froze up but all there, Woopie! Might have to look into that. It's just a woman and been setting for long time in yard. Has a loader too, but looks homemade and wouldn't stay on it, for me anyway. NOW, to make offer and figure how to get IT home!!! :rolleyes:
