| | | Forums66 Topics128,168 Posts1,057,098 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2004 Posts: 148 Member | | Member Joined: Sep 2004 Posts: 148 | i am purchasing a 55.2 for parts for my 59 (cab, fenders, bed pieces)
it is non running, so it is just a roller. is a come-along my only option to load it?
2003 ford lightning 1959 chevy 36
| | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | | | | | | Joined: May 2005 Posts: 147 Shop Shark | | Shop Shark Joined: May 2005 Posts: 147 | Friend mounted a electric winch on the front of his trailer, a bit pricey. Works great. | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | lock the trailer down and push it with your truck then re-hook up, maybe get a long tow chain , lock the trailer down and pull from front of the trailer,,a come-along will work, just takes a little time and muscle,,use to load a 3300 pound car this way,,,Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Jan 2003 Posts: 24 Junior Member | | Junior Member Joined: Jan 2003 Posts: 24 | The problem I had with a come-along was that the cable was reeled all the way in when the truck was only half way up the ramp. I had no way to move the truck up the one more inch or so necessary to release the ratchet on the come-along.
It was in that position for about an hour before a solution presented itself (we ended up pulling the truck up the ramp with another truck). | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I have used two come-alongs to avoid that, also adds some safety, then use the come-along to bind the truck down w/chain for the trip home. Brian | | | | | Joined: Aug 2004 Posts: 476 Moderator | | Moderator Joined: Aug 2004 Posts: 476 | If you use anything with any speed, make sure you can get it stopped before it creams the front of your trailer or the back of your truck.
I let some guys use my trailer to haul a dead car. They forgot to hit the brakes when they got it up on the trailer (4 or 5 guys pushing) and busted up all the front end plastic on the front of my trailer. Didn't hurt the trailer, but turned the car from a fixer upper to not worth fixing.
Don't lose your head to save a minute, You need your head, your brains are in it. Burma-Shave (1947)
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I've used people, a come-along, a chain to another vehicle, but what I like best was a truck with a front mounted hitch and winch.
I'd set the trailer on the front hitch, and then use the winch to drag the load onto the trailer. It was a great arrangement if you were doing a one-man load opperation.
Unfortunately my dad sold both the trailer and the truck with the winch about 30 years ago.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Apr 2004 Posts: 543 Shop Shark | | Shop Shark Joined: Apr 2004 Posts: 543 | An electric winch is the ONLY way I'll load a trailer, unless the car is drivable, of course! Did the come-along nonsense for far too long! I sold trailers for several years, and when I built and designed my own trailer, I decided it would have a large electric winch on the front as part of the design. It's an 18' wood deck flat (16'+2' steel dovetail). Hauled a 1950 Dodge B-2-HHA (2-ton dually) from central Nebraska to central Oklahoma on it, and that winch was worth its weight in gold that day, I tell ya!!!
Pessimist - Sees glass as half-empty. Optimist - Sees glass as half-full. Gov't- Sees glass and takes it from you because you have a glass. Political Correctness: A philosophical belief system bereft of common sense and logic, that supports and rewards ignorance and stupidity.
| | | | | Joined: Oct 2000 Posts: 112 Shop Shark | | Shop Shark Joined: Oct 2000 Posts: 112 | Oh, I used a come a long , a 5/16 chain and a u-haul trailer, to drag the burb out of the garage, and come a long til rear wheels touch ramps, then rehook to center or front of truck and come a long it up the ramps and up the trailer. all along thinking why didn't I get one of those electric wenches. Jbennett 40 burb | | | | | Joined: Sep 2004 Posts: 148 Member | | Member Joined: Sep 2004 Posts: 148 | found a better solution:
the repo man we use at work will meet me there with a flatbed tow truck, and drop it off at my house for $50 to cover the fuel.
that seems to be the best solution i could come up with :-P
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | good deal. anyways...I use two come a longs, didnt work to bad. | | | | | Joined: May 2005 Posts: 5 Junior Member | | Junior Member Joined: May 2005 Posts: 5 | method I use, jacknife the truck and trailer and use a second vehicle to pull you car onto the trailer. Tie a cable to the front of the pulling vehicle and across the trailer to the car you are loading. You have a clear view of the car you are pulling up onto the trailer. | | | | | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | I loaded my last one using a CAT 966 loader with forklift arms;easy,and,if you're careful where you run the forks,easy on the vehicle you're loading,plus,you can set the car/truck onto a 2-1/2 ton flatbed without having to worry it up a big ol' set of ramps. Gravity will handle the unloading part of the exercise.(A loading dock is better for the vehicle's health) James | | |
