Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (Rich'sToys, Hotrod Lincoln), 129 guests, and 4 robots.
Topics128,281
Posts1,058,465
Members48,490
#181103 01/28/2005 3:00 PM
Getting ready to pull the cab off my 53 half ton. Should I remove the glass or not? Will probably use four people to lift it. Need to set it on my new frame for engine placement.
#181104 01/28/2005 5:01 PM
yes- remove the glass and replace it. 1953 -should be pretty scratched and dull by now. New glass will be beautiful
#181105 01/28/2005 8:44 PM
Pulling the glass will make it lighter. But where are you going to store the cab? I have one sitting in the back yard and I left the glass in it to help keep the weather out.
