3 members (JW51, TexasJim50, Sjm),
90
Mod | | | Forums66 Topics128,271 Posts1,058,417 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2001 Posts: 115 'Bolter | | 'Bolter Joined: May 2001 Posts: 115 | My buddy from here has 1942 Chevy 3/4 ton truck. It does not have the original rear end. It fits very well, still 6 lug, and has a stabilizer built in. It is the nicest driving old truck I have driven in a long while and I attribute part of that to the raio in the rear end. I would sure like to know what it is out of? I will go figure out the ratio in the next week or so. Here are a few pictures- http://community.webshots.com/album/547621393NkIufX Any idea what it is from?
Brian D
| | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | Are there any kind of numbers on it?
What engine is he running, the stock 6? Still the stock tranny? What kind of top speed is he getting?
I ask, because in the future, i'd like to swap rear ends eventually to get a little better top end speed.. but I really love my 216 and the reverse lockout on the 4 speed stock tranny.
Silly I know, but if I can get a little better highway speeds (in the 60MPH range) i'd rather keep the stock motor and swich to a 4 speed with an open driveshaft (like out of a 3/4 ton) and just swap out the rear.
So i'm pretty curious as to what your buddies truck has for a back end, too!
| | | | | Joined: Mar 2005 Posts: 284 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 284 | Any chance you have the plans for the box on the 42.It sure looks good. | | | | | Joined: May 2001 Posts: 115 'Bolter | | 'Bolter Joined: May 2001 Posts: 115 | The truck has a 235 with an SM420 4 speed. It cuises easily at 60 with low rpm's. No problems on hills either. I had the truck up to 70 (I hope Robert is not reading this). I do not have plans for the bed. It was homemade before I got the truck. It was nice having the boxes on the flatbged. Looked good too.
Brian D
| | | | | Joined: Nov 2005 Posts: 146 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 146 | looks like your average 60s car rear end to me.even 70s cars had the rear like that bet its a 10 bolt :p | | | | | Joined: May 2001 Posts: 115 'Bolter | | 'Bolter Joined: May 2001 Posts: 115 |
Brian D
| | | | | Joined: Oct 2003 Posts: 363 Member | | Member Joined: Oct 2003 Posts: 363 | you can get a 6 lug 10 bolt out of a late 60s or early 70s 4x4 truck or blazer that won't be too wide.
3/4 ton trucks have 8 lugs | | |
