15 members (Otto Skorzeny, Jims46, Hawkman, Southerntruck, J Lucas, D B Cooper, Oldcaliforniakid, Stovebolt48, Bill Hanlon, Peggy M, DadsFirstPickup, Ponchogl, Hotrod Lincoln, 32Fordpuchoptop, 1 invisible), 92 guests, and 1 robot.
Topics128,049
Posts1,055,674
#18026 03/18/2004 4:23 PM
is there much diffrance between the look of a 207 and a later stovebolt.is there a site with pic of the motors.
#18027 03/19/2004 1:19 AM
I think there are exterior differences in the head both on the ignition side and the manifold side. I will have to do a little research on that. Also, the 216 has the oil distributor valve which was an improvement, I just don't know if the early 216s had them.
1951 1 Ton Completed
#18028 03/19/2004 2:47 AM
Take a look at my 35, The one that is in the car is a 207 and the red one is a 54 235. I think you can get kits to have the bolts come through the valve cover and use a 216 valve cover. There is size differences in the engines though the 207 is 1.5 inches longer than the 235.
I have had a dissussion with a engine swap on the 207 to a 235.
