| | | Forums66 Topics128,038 Posts1,055,584 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#18026 03/18/2004 4:23 PM | Joined: Dec 2002 Posts: 7 Member | | Member Joined: Dec 2002 Posts: 7 | is there much diffrance between the look of a 207 and a later stovebolt.is there a site with pic of the motors. | | |
#18027 03/19/2004 1:19 AM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I think there are exterior differences in the head both on the ignition side and the manifold side. I will have to do a little research on that. Also, the 216 has the oil distributor valve which was an improvement, I just don't know if the early 216s had them. | | |
#18028 03/19/2004 2:47 AM | Joined: May 2003 Posts: 90 Member | | Member Joined: May 2003 Posts: 90 | Take a look at my 35, The one that is in the car is a 207 and the red one is a 54 235. I think you can get kits to have the bolts come through the valve cover and use a 216 valve cover. There is size differences in the engines though the 207 is 1.5 inches longer than the 235.
I have had a dissussion with a engine swap on the 207 to a 235. | | |
