| | | Forums66 Topics128,077 Posts1,056,013 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2000 Posts: 203 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 203 | I've had a few negative comments about my rear turn signals. In front I converted the the park lights and in the rear I used two F ord pickup marker lights on either side. I was considering putting lights in the ends of the rolls on top of the frame rails.
I was wondering if anyone has found a good supplier of such or an idea of what works well. | | | | | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | Here is a copy of an E-mail I received. Someone on this board has these LEDs in the roll. The supplier is pros-pic.com??? As follows; Believe it or not the Led lights will work on 6 volts and they are not substantially dimmer -----Original Message----- From: Pro's Pick [mailto: [email protected]] Sent: Tuesday, January 13, 2004 9:20 AM To: [email protected]Subject: FW: -----Original Message----- Sent: Monday, January 12, 2004 3:07 PM To: [email protected]Subject: I am looking at a pair of your bed roll lights in LED. My question…My 46 Chevrolet truck is running on 6 volt. Do you have a set of bed roll lights that will work for the old 6 volt system? Thanks John | | | | | Joined: Jan 2004 Posts: 288 Shop Shark | | Shop Shark Joined: Jan 2004 Posts: 288 | Horvath, A member of this site has LED lights in his bed rolls. Here is his link to his website. web page Chris
Chris 1955FirstSeries
| | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | I have neon paint on my hands and arms, works well, then you can give a non-traffic signal if you wanna  nice to hear from you skip...Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Nov 2012 Posts: 15 New Guy | | New Guy Joined: Nov 2012 Posts: 15 | The led lights are available for the bed rolls but are expensive. I turned a couple of dowels on a wood lathe, a piece of closet rod would work, and drilled a hole in the center. I then fitted a pair of led marker lights from Advanced Auto in the holes' painted the wood black and ran wires down the standard pocket to the turn signal switch. I pushed the assemblies into the bed with a little black silicon for glue. They are not even noticeable when off and very bright when turning. Less than 12 bucks spent. | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Wow, talk about resurrection of an old thread! 14 years, that’s gotta be a new record. Post a photo so we can see your creative idea.ðŸ›
BTW, the only member to that discussion who is still around is Fatfenders and his last post is a year old.
| | | | | Joined: Jun 2008 Posts: 1,644 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 1,644 | An oldie, but a goodie. (The thread that is)
Chuck 1950 Chevy 1/2 ton (all original) 1951 Chevy 1/2 ton (future streetrod) 1941 Chevy coupe 1938 Chevy coupe streetrod | | |
